Respray
How easy is spraying...?
As with most things you learn from your mistakes - best not to practice on your range rover sport!! :)
It's the prep work which is most time consuming - also usefull to have a dry / preferably heated indoor dust free space to do it in..
Spraying is relatively straight forward if you have the gear, it's the prep work that takes the time and to a large extent determines the quality of the finish. If you have the time (and space) to practice beforehand then you should be able to make a presentable job - but don't underestimate what's involved.
one advantage for both
Doing it yourself:- CAN SAY I APINTED THAT
Someone else doing it:- IF YOUR NOT HAPPY WITH QUALITY OR ITS NOT RGHT - ITS UP TO THEM TO PUT IT RIGHT.
patience and time is the key to it in the prep, dont think that'l do - it wont
dont skimp on paint or equipment but dont buy the top of the range if you paint once in a blue moon.
 Share
