DC_ Posted August 18, 2021 Share Posted August 18, 2021 Hi guys, fresh MOT on the Landy today. Had an advisory for the radius arms bushes. So parts are coming. Getting down to put the penetrating lube on the bolts and nuts I noticed this on my axle and it seems to be welded to the bolt of the radius arm on both sides of the axle in the same place (one at either end)ย ๐คย Has anyone ever seen this? Iโm thinking to grind it off to get the impact on the nut. Just weird โฆโฆ Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 18, 2021 Share Posted August 18, 2021 Never seen anything like it before, but perhaps it was to fit a second set of dampers, in a similar way to the air sprung RRCs? Bodgerific of course... 1 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted August 18, 2021 Share Posted August 18, 2021 I agree with Bowie, looks like a bodged second damper mount. I'd cut it off completely. Mike 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 18, 2021 Share Posted August 18, 2021 Yep cut it off grind it from existence then you will have never seen the like and will not need to ask why lol regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
DC_ Posted August 18, 2021 Author Share Posted August 18, 2021 Itโs Ex MoD so I was thinking might be something to do with that. Yes itโs gettingย erased from existence for sure. Very weird though ๐ Quote Link to comment Share on other sites More sharing options...
DC_ Posted August 19, 2021 Author Share Posted August 19, 2021 Another suggestion from someoneโฆโฆ the hole that the radius bolt goes through has ovalised so instead of fixing that, they bodged it like this? ๐ค Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 19, 2021 Share Posted August 19, 2021 4 minutes ago, DC_ said: Another suggestion from someoneโฆโฆ the hole that the radius bolt goes through has ovalised so instead of fixing that, they bodged it like this? ๐ค Seems like a lot of trouble when you could just weld new washers of correct diameter in place regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted August 19, 2021 Share Posted August 19, 2021 You've got to love a proper bodge job ๐๐ Mo 2 Quote Link to comment Share on other sites More sharing options...
smallfry Posted August 19, 2021 Share Posted August 19, 2021 WTF ? A damper mount ? With that welding ? I bet the MOT man thinks you did it, and will be nudging each other and whispering next time you go inย ๐ 1 Quote Link to comment Share on other sites More sharing options...
cackshifter Posted August 19, 2021 Share Posted August 19, 2021 Maybe it could be a nominee for a forum Bodge Of The Year award. Best Unsupporting Metalwork? 2 Quote Link to comment Share on other sites More sharing options...
DC_ Posted August 19, 2021 Author Share Posted August 19, 2021 As longย as I donโt get the blame ๐๐ This was suggested again to be a twin damper mount....... I guess weโll never know.ย ย ย Quote Link to comment Share on other sites More sharing options...
DC_ Posted August 21, 2021 Author Share Posted August 21, 2021 One side off and no sign of any main reason for the weldy weld thingymajig. ๐ ย ย Quote Link to comment Share on other sites More sharing options...
DC_ Posted August 22, 2021 Author Share Posted August 22, 2021 Nearside bushes were in a howler of a state. Bodge now gone, tricky to get in at it.ย Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted August 22, 2021 Share Posted August 22, 2021 We should call you Jack from now on, DC ๐๐ Mo 1 1 Quote Link to comment Share on other sites More sharing options...
DC_ Posted August 22, 2021 Author Share Posted August 22, 2021 Naw, โbottleโ maybe.... as when I was grinding that โthingโ off, I was bottling it. ๐๐ Quote Link to comment Share on other sites More sharing options...
