defender dinky Posted August 18, 2021 Share Posted August 18, 2021 Hi all, range rover vogue se v8 efi auto 1988, almost ready for start up, firstly new tank, pump and sender installed so tanks empty, head gasket and any other gasket that came with kit fitted, new crankshaft bearing, new camshaft and bearings fitted all lubed up, new followers fitted push rods, engine and rocker covers cleaned thoroughly, new timing chain kit fitted, oil pump jelled up, new oil filter filled up and fitted, plus loads more, wondering what startup procedure is, do I leave plugs out for instance, any advice appreciated, dd Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 18, 2021 Share Posted August 18, 2021 Crank it up and get it to around 2000rpm and keep it there for 20 mins, no need to manually prime if you have well lubed everything during assembly. Quote Link to comment Share on other sites More sharing options...
defender dinky Posted August 18, 2021 Author Share Posted August 18, 2021 I was thinking of fuel lines being empty, might be a lot of cranking before fuel gets through, dd Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 18, 2021 Share Posted August 18, 2021 Electric fuel pump, no? Quote Link to comment Share on other sites More sharing options...
defender dinky Posted August 18, 2021 Author Share Posted August 18, 2021 Electric fuel pump, yes, lol Quote Link to comment Share on other sites More sharing options...
