Transfer box part conundrum
Hi all,
I've actually started to reassemble things now, and cleaning the high/low selector and diff lock showed me an interesting little foible. The circlip is missing from the pin that holds the selector mechanism onto the selector lever.
My manual says it should be a pin with a washer and split-pin, (parts PC108321, WA108051L and PS104127L respectively) but mine definitely should have a circlip instead. Is this a field mod (in which case it was a bad one), a later (or earlier) build or just a Landy?
And if it should be the circlip, can anyone tell me the part number?
Thanks,
SB
