monkie Posted September 21, 2021 Share Posted September 21, 2021 On 9/19/2021 at 10:16 AM, cackshifter said: Correct me if I'm wrong but if one blocks the tank vent except when in use, does that not go some way towards alleviating the problem? I wouldn't have thought so as the air enters the tank as the petrol level drops when in use. The best bet would be to keep the tank above half full where possible. I'm not sure how much an issue this really is to be honest. Water in a diesel tank builds up from condensation forming from the air in a partly filled tank. Petrol however has a much higher vapour pressure than diesel does and the ethanol content of the fuel will stop it from just sitting there as it will in a diesel tank, so I can't see this being the issue some people claim. I'm sure this will just blow over with E10 petrol. Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted September 21, 2021 Share Posted September 21, 2021 So the general gist is that you may need to replace your fuel hose and o-rings on your injectors, but it should run fine in your Rover V8? Steve Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 21, 2021 Share Posted September 21, 2021 Yes. Running fine in my 91 audi coupe quattro 20v. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 21, 2021 Share Posted September 21, 2021 1 hour ago, steve200TDi said: So the general gist is that you may need to replace your fuel hose and o-rings on your injectors, but it should run fine in your Rover V8? I've not even done those - my fuel hose is all recent enough (as in, manufactured this millennium) and I've never seen any issue with the injector seals. Only thing I suspect was damaged by E-something fuel somewhere in Europe was the old-style cork seal on the fuel pump to tank joint, but that may just be an unlucky coincidence. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 21, 2021 Share Posted September 21, 2021 The audi is running its original fuel hoses from the factory, hopefully they will survive Quote Link to comment Share on other sites More sharing options...
Snagger Posted September 22, 2021 Share Posted September 22, 2021 E85 will be half the price until the bulk of petrol sales are of that, and then the price will shoot up to around the cost of E10. It’s the same old ploy around the world, done with diesel in the 80s, lpg in the 90s, diesel again in the 00s, and now EVs in the 20s - subsidise the early adopters, then once the public have been swayed into following government policy, bleed them dry. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 22, 2021 Share Posted September 22, 2021 E85 won't be suitable for a lot of cars, it has a much lower calorific value compared to regular petrol. Quote Link to comment Share on other sites More sharing options...
rusty_wingnut Posted September 22, 2021 Share Posted September 22, 2021 9 hours ago, FridgeFreezer said: I've not even done those - my fuel hose is all recent enough (as in, manufactured this millennium) and I've never seen any issue with the injector seals. Only thing I suspect was damaged by E-something fuel somewhere in Europe was the old-style cork seal on the fuel pump to tank joint, but that may just be an unlucky coincidence. I've done even less than that on my Series 1 - still runs fine with no leaks. I haven't noticed an affect on the cork gaskets on the tank. 1 Quote Link to comment Share on other sites More sharing options...
reb78 Posted September 22, 2021 Share Posted September 22, 2021 3 hours ago, rusty_wingnut said: I've done even less than that on my Series 1 - still runs fine with no leaks. I haven't noticed an affect on the cork gaskets on the tank. Thats reassuring as it suggests the carb and fuel pump components will cope. I guess this is short term at the moment as e10 hasnt been around for long yet? Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted September 24, 2021 Share Posted September 24, 2021 If the queues at all the service stations I have seen around here are anything to go by it would appear that the media has convinced gullible Joe Public that the end of the world is nigh in terms of deliveries of petrol and diesel are concerned. 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 24, 2021 Share Posted September 24, 2021 Yep, just had a chat with a taxi driver, he's almost on empty, and clearly needs it to work. The world can be full of selfish..... when push comes to shove. I have half a tank (about 150 miles) and will fill up once all this blows over and the service stations are like ghost towns. Quote Link to comment Share on other sites More sharing options...
reb78 Posted September 24, 2021 Share Posted September 24, 2021 I need to do 600 miles next week. AmI going to get stick somewhere because someone else has bought all the fuel they dont need?! Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 24, 2021 Share Posted September 24, 2021 Like I said selfish........ Quote Link to comment Share on other sites More sharing options...
missingsid Posted September 24, 2021 Share Posted September 24, 2021 I just got back from Portsmouth on empty, got to petrol station to find massive ques, didn't know why, luckily the twats didn't que at the proper entrance so I bypast them all to a spare pump! When I was done the que went down the road. 2 Quote Link to comment Share on other sites More sharing options...
reb78 Posted September 24, 2021 Share Posted September 24, 2021 Will it be over next week when all the idiots have full tanks and dont need fuel? I have enough diesel to do the first 300 miles of my work run next week bit may not get back! Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 24, 2021 Share Posted September 24, 2021 From the last fuel crisis, motorway services were heavily prioritised, as recovering people out of fuel is a lot harder when on a motorway! So suggest you try there, @reb78.... My suspicion is it will all be over by then. Quote Link to comment Share on other sites More sharing options...
reb78 Posted September 24, 2021 Share Posted September 24, 2021 Why does this happen when the 110 is off the road long term?!! I have hundreds of litres of SVO. I cant use that in the D2 or D3 though! Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted September 26, 2021 Share Posted September 26, 2021 It's God's punishment for you putting SVO in the 110 😁😇 Mo Quote Link to comment Share on other sites More sharing options...
elbekko Posted September 26, 2021 Share Posted September 26, 2021 Guess we'll fuel up in Calais and take it easy next week then Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 26, 2021 Share Posted September 26, 2021 Assume people will take anything right now 😛 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted September 26, 2021 Share Posted September 26, 2021 I was due to pick some wheels up for the 90 today - but no diesel left anywhere round here… Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted September 27, 2021 Share Posted September 27, 2021 ... and those stations that have diesel have shoved the price up ! Mo Quote Link to comment Share on other sites More sharing options...
miketomcat Posted September 27, 2021 Share Posted September 27, 2021 I had to go home a nick the wife's truck this morning because the retards have bought all the diesel, so I couldn't fill up on the way to work. Mike Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted September 27, 2021 Share Posted September 27, 2021 Thankfully not seeing any of your fueling issues up here..........yet regards Stephen Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted September 27, 2021 Share Posted September 27, 2021 It does seem to mainly an urban problem. Although there are so few fuel stations left , out in the sticks, that being rural isn't as much of a blessing as one could wish. Quote Link to comment Share on other sites More sharing options...
