SlickV8 Posted September 8, 2021 Share Posted September 8, 2021 Hi all, Ive a series 2 with a RR classic 3.5 V8. I've fitted a high torque cam and new edlebrock carb / manifold. i cant say that oil consumption was anything i worried about prior to the conversion but It seems to be using around 1 ltr oil per tank of petrol now and I'm thinking i maybe should add a pcv valve? The carb came with the pcv port blanked off but I assume its simple enough job to fit one. I'm planning on a rebuild at some point but I'd like to try and establish if the oil consumption is down to the plumbing or good old fashioned wear, although it didn't seem to burn it so quick before the carb conversion. Currently I've a pipe from the o/s rocker cover, through a flame trap and into the air filter port and the n/s rocker is the same but from memory into a port on the back of the carb. Could this cause too much vacuum, too little? do you think a pcv valve would help? The engine does blow a puff of smoke on throttle after coasting but it doesnt have valve guide seals so i expect that. It also seems to blow a little on reasonable heavy throttle but certainly never plumes of smoke thanks in advance Quote Link to comment Share on other sites More sharing options...
Tanuki Posted September 8, 2021 Share Posted September 8, 2021 I'd be checking the air/fuel ratio. A rich mixture will wash oil from the bores and increase oil consumption as well as causing increased bore-wear. [in practice, matching a non standard carb setup and camshaft _properly_ along with getting the ignition-timing/advance-curve correct will involve a good bit of rolling-road time] 1 Quote Link to comment Share on other sites More sharing options...
missingsid Posted September 8, 2021 Share Posted September 8, 2021 On the original twin carb setup the air was drawn in via a small pipe at rear of the block below the valley gasket via a small filter looks the same as a fuel filter to a port at the air cleaner. The larger outlet pipes went from both rockers to ports on the vacuum side of both carbs. Thus there is more volume drawn into the carbs than it is possible for the input to supply drawing fumes from the engine into the carbs. Later engines had a filtered inlet on one rocker cover and an outlet on the other rocker cover going to the throttle body. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 8, 2021 Share Posted September 8, 2021 If you are zoning that set up, and allowing the engine to draw on the crankcase from under the butterflies, you need a restrictor, around 4mm, or it is permanently aucking oil vapour out of the crank case. The EFI engines used that exact setup, and without the restriction it runs very rough, be surprised if you don't need to return the idle at least, once you have this sorted. Quote Link to comment Share on other sites More sharing options...
missingsid Posted September 9, 2021 Share Posted September 9, 2021 9 hours ago, Bowie69 said: If you are zoning that set up, and allowing the engine to draw on the crankcase from under the butterflies, you need a restrictor, around 4mm, or it is permanently aucking oil vapour out of the crank case. The EFI engines used that exact setup, and without the restriction it runs very rough, be surprised if you don't need to return the idle at least, once you have this sorted. Ah yes the stubs on the carbs are very thick walled. Quote Link to comment Share on other sites More sharing options...
SlickV8 Posted September 10, 2021 Author Share Posted September 10, 2021 On 9/8/2021 at 8:17 PM, Bowie69 said: If you are zoning that set up, and allowing the engine to draw on the crankcase from under the butterflies, you need a restrictor, around 4mm, or it is permanently aucking oil vapour out of the crank case. The EFI engines used that exact setup, and without the restriction it runs very rough, be surprised if you don't need to return the idle at least, once you have this sorted. thanks all. i dont quite understand what you mean buy drawing [air?] from under the butterflies? is that meaning the n/s pipe i mentioned going to the back of the carb? If so then i what form of restrictor should i use? Sorry if i'm being thick Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 10, 2021 Share Posted September 10, 2021 Well, if you have the vacuum connection under the butterflies (sometimes called 'manifold vacuum'), at idle, the crankcase will be being put under enormous vacuum, as the engine is sucking hardest in this condition. The engine, drawing that vacuum on the breather will suck air through the breather pipe, thropugh the crankcase, out the other rocker through the breather you have attached , through the flame trap and into the air filter where it can get all the air it wants. If the pipe going to the carb is too big it will suck WAAAY to much air through, and pick up oil vapour along the way, giving you blue smoke, especially after idle or as you have said, coasting. You need a restrictor so the engine isn't able to suck through too much air through the crankcase, a 4mm restrictor is what the EFI engines use, so I would start there. It needs to go just before your breather pipe goes into the carb. If we knew what model edelbrock you had, we may be able to find a more suitable port.? Quote Link to comment Share on other sites More sharing options...
missingsid Posted September 10, 2021 Share Posted September 10, 2021 Just to add, it is common for both ends of the pipes to appear to come from a similar location as described above but the air preasures are different. The air in pipe feeds from the atmospheric preasure area before the air filter or at least before the butterfly. This is because the air filter opening is designed to be free from water and dirt and so is a convenient location to source it. From my experience, a PCR valve is just a one way valve which opens when the engine is running but will close if there is a backfire or any positive preasure in the manifold, it may not offer any flow reduction. Quote Link to comment Share on other sites More sharing options...
SlickV8 Posted September 11, 2021 Author Share Posted September 11, 2021 Couple of pics attached. It’s the edelbrock/ Weber 500 and manifold. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 13, 2021 Share Posted September 13, 2021 OK, so a bit of investigation leads to me say a few things.... - The port on the back of the carb you have connected is designed for the brake servo/booster or vacuum line to the autobox (some use vacuum to decide when to shift). This will be direct to the manifold, and is therefore NOT suitable for your crankcase ventilation without a (~4mm?) restrictor. - You appear to be missing, or have plugged the PCV port on the front of the carburettor, see image below. This is likely where you need to connect your crankcase vent, it will be pre-butterflies, and draw a lot less vacuum, more to the point, it is designed for it. What did the instructions/seller say? - Your vacuum advance hose is in the right please, have a cookie 😛 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 14, 2021 Share Posted September 14, 2021 Just to add: no flame traps fitted? Quote Link to comment Share on other sites More sharing options...
SlickV8 Posted September 24, 2021 Author Share Posted September 24, 2021 apologies for delayed response, the day jobs gone a bit mad this month thats really helpful, thank you. I'd taken the flame traps off while messing around last time. I'll speak to the carb supplier about the PCV port, it arrived blanked off but I'm sure theres a solution I'm hoping to get back on it this weekend so I'll let you know results Quote Link to comment Share on other sites More sharing options...
SlickV8 Posted September 24, 2021 Author Share Posted September 24, 2021 just a quick thought...i guess i don't NEED to introduce a PCV? I don't think these engines had them in standard form? On the theory that vacuum is drawing too much oil/vapour up could I either 'T' the n/s rocker cover pipe into the o/s one so the both vent into the underside of the air filter or maybe just plumb the n/s into an oil catch tank, so there'd be no vacuum? I've also fitted a remote brake servo which i currently have piped to the top of the inlet manifold [see the second picture] - it works fine tbh but should i really blank off the manifold port and route it to the port on the back of the carb? I assume there'd be little difference but would that be the 'proper' way to do it? Quote Link to comment Share on other sites More sharing options...
=jon= Posted September 24, 2021 Share Posted September 24, 2021 1 hour ago, SlickV8 said: On the theory that vacuum is drawing too much oil/vapour up could I either 'T' the n/s rocker cover pipe into the o/s one so the both vent into the underside of the air filter or maybe just plumb the n/s into an oil catch tank, so there'd be no vacuum? If you do away with the vacuum entirely, you may find you end up with oil leaks - on my fresh built 4.6 with the breathers setup incorrectly it would force oil past the crank pulley seal after extended high revs. Changing to the factory 4.6 setup (air drawn in from air filter on n/s bank, through engine, o/s with restrictor and spiral separator to inlet post throttle) cured it. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 24, 2021 Share Posted September 24, 2021 Yup, the PCV port is ideal in this Quote Link to comment Share on other sites More sharing options...
