Nonimouse Posted October 6, 2021 Share Posted October 6, 2021 23 minutes ago, Jocklandjohn said: Unless of course the Glencoyne spacer has got fairy dust on it? Could it make that difference to pump operation?? Interesting question - I can't see why. But...the engine I fitted last year is the best 'standard' 200tdi I've driven and I put a Glencoyne spacer on it before fitting. I only use Delphi pumps... It's got minor tweaks, yes. But nothing like the last lump and yet it pulls better. Loads of lower down grunt and so smooth. Might be the fact it's a Goldseal lump, but who knows. Maybe it is magic Quote Link to comment Share on other sites More sharing options...
Jocklandjohn Posted October 6, 2021 Author Share Posted October 6, 2021 Curious - if the pump arm is moved further away from the cam (thus reducing movement range) does the consequent fuel volume being moved affect the feeding of the FIP in some way? My experience today is *almost* as if an over-fuelling state has been reduced somehow. Obviously other issues may be afoot (I still need to check air hoses for leaks/problems) - timing belt change and fuel pump timing check are booked for a few weeks so once all that is done the main culprits will have been eliminated. Quote Link to comment Share on other sites More sharing options...
reb78 Posted October 6, 2021 Share Posted October 6, 2021 2 hours ago, Jocklandjohn said: Curious - if the pump arm is moved further away from the cam (thus reducing movement range) does the consequent fuel volume being moved affect the feeding of the FIP in some way? My experience today is *almost* as if an over-fuelling state has been reduced somehow. Obviously other issues may be afoot (I still need to check air hoses for leaks/problems) - timing belt change and fuel pump timing check are booked for a few weeks so once all that is done the main culprits will have been eliminated. No, i dont think so. My understanding is that you need to keep the FIP supplied well and any excess just goes back to the tank in the return line. It wont force it to over fuel if you push more fuel into it. Quote Link to comment Share on other sites More sharing options...
western Posted October 6, 2021 Share Posted October 6, 2021 Maybe worth reposting this thread, I've never found a need to add any spacers to the lift pump mounting plate to my 200tdi, they should all have this built in spacer, IIRC my lift pump is a Delphi unit & has been fitted for more than 10years, engine pulls very well in all conditions. Quote Link to comment Share on other sites More sharing options...
Jocklandjohn Posted October 6, 2021 Author Share Posted October 6, 2021 41 minutes ago, western said: Maybe worth reposting this thread, I've never found a need to add any spacers to the lift pump mounting plate to my 200tdi, they should all have this built in spacer, IIRC my lift pump is a Delphi unit & has been fitted for more than 10years, engine pulls very well in all conditions. Yes I've read your post several times when i was looking for advice Ralph, and all I can say is 'Its a Land Rover thing and it puzzles me. Again!". The Glencoyne spacer is less thick than the nylon spacers that I've occasionally found in lift pump boxes, and Glencoyne themselves make a clear distinction between putting the spacer on the mounting plate you show (I presume) and the bare block: "...all four cylinder 2.25 / 2.5 engines with the cast aluminium pump mounting plate, and 300TDi engines where the pump is bolted direct to the block". Its all very confusing! Quote Link to comment Share on other sites More sharing options...
western Posted October 6, 2021 Share Posted October 6, 2021 Your right there with it being confusing, the lift pump lobe on the cam is a off centre circular lobe, not like the actual valve lobes, I don't know why some need the Glencoyne spacer & other do't. Quote Link to comment Share on other sites More sharing options...
Jocklandjohn Posted October 6, 2021 Author Share Posted October 6, 2021 1 hour ago, western said: Your right there with it being confusing, the lift pump lobe on the cam is a off centre circular lobe, not like the actual valve lobes, I don't know why some need the Glencoyne spacer & other do't. As far as I can establish from reading about it, the nylon spacer *seems* (at least on some engines) to move the pump arm out so far that it won't operate. However the slightly thinner Glencoyne spacer does allow operation, but the range of movement is less, thus preventing over-stressing of the arm/linkage and premature failure. I think! But I could be completely wrong! 1 Quote Link to comment Share on other sites More sharing options...
Maverik Posted October 7, 2021 Share Posted October 7, 2021 To add to an old topic - but seems the best place to put it. Early engines I believe had this type of mounting which is what came from the series engines which the TDI's where ultimately derived, I was reading part of the service manual yesterday and in that it states the 200tdi was designed to use a lot of parts from previous engines. This is a picture of the early fuel pump mounting plate, as you can see compared to the cast aluminum type as Ralph has posted there is no stand off. - if you put a later type fuel pump on this type of mount then you can suffer lift pump arm damage. 1 Quote Link to comment Share on other sites More sharing options...
Jocklandjohn Posted October 7, 2021 Author Share Posted October 7, 2021 15 minutes ago, Maverik said: To add to an old topic - but seems the best place to put it. Early engines I believe had this type of mounting which is what came from the series engines which the TDI's where ultimately derived, I was reading part of the service manual yesterday and in that it states the 200tdi was designed to use a lot of parts from previous engines. This is a picture of the early fuel pump mounting plate, as you can see compared to the cast aluminum type as Ralph has posted there is no stand off. - if you put a later type fuel pump on this type of mount then you can suffer lift pump arm damage. Hmmm. Is there any VIN or age related info for when the later plate was added, or is it just a case of look and see? Quote Link to comment Share on other sites More sharing options...
western Posted October 7, 2021 Share Posted October 7, 2021 Can't see any ref to VIN in the parts book, only -- From June 1994. 1 Quote Link to comment Share on other sites More sharing options...
Maverik Posted October 7, 2021 Share Posted October 7, 2021 1 hour ago, Jocklandjohn said: Hmmm. Is there any VIN or age related info for when the later plate was added, or is it just a case of look and see? I'd say its a more look and see. Pretty obvious. - and it makes sense really - its why all "new" lift pumps come with the spacer so they are back compatible with the older engine type. 2 Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted October 9, 2021 Share Posted October 9, 2021 This plate has been made from cast iron as well 1 Quote Link to comment Share on other sites More sharing options...
muddy Posted October 12, 2021 Share Posted October 12, 2021 you have a N/A or turbo diesel air filter, these are smaller than a TDi one, also your intake pipework doesn't seem right with the large silicone pipes, are these home made? if so what ID are they? I think you said you don't but do you have a larger TDi exhaust on there? A friend of mine had a genuine defender 200 in a TD and we never could get it to pull right, unfortunately it got stolen before we could get to the bottom of it. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted October 12, 2021 Share Posted October 12, 2021 6 hours ago, muddy said: you have a N/A or turbo diesel air filter, these are smaller than a TDi one, also your intake pipework doesn't seem right with the large silicone pipes, are these home made? if so what ID are they? I think you said you don't but do you have a larger TDi exhaust on there? A friend of mine had a genuine defender 200 in a TD and we never could get it to pull right, unfortunately it got stolen before we could get to the bottom of it. Td and 200TDi exhausts are the same except the hangers. The td downpipe is also significantly easier to remove because it has an extra join in it. Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted October 14, 2021 Share Posted October 14, 2021 I put a TD5 exhaust into my 200 Tdi. The tube is wider. Needs some translation. https://www-explorermagazin-de.translate.goog/bauberi/defaus21.htm?_x_tr_sl=auto&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=nui Has got a lot more torque in low revs. But I think it has nothing to do with this problem. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted October 15, 2021 Share Posted October 15, 2021 On 10/6/2021 at 4:25 PM, Nonimouse said: Interesting question - I can't see why. But...the engine I fitted last year is the best 'standard' 200tdi I've driven and I put a Glencoyne spacer on it before fitting. I only use Delphi pumps... It's got minor tweaks, yes. But nothing like the last lump and yet it pulls better. Loads of lower down grunt and so smooth. Might be the fact it's a Goldseal lump, but who knows. Maybe it is magic Gold seal 200TDis are a myth.... Quote Link to comment Share on other sites More sharing options...
Maverik Posted October 15, 2021 Share Posted October 15, 2021 21 hours ago, Sigi_H said: I put a TD5 exhaust into my 200 Tdi. The tube is wider. Needs some translation. https://www-explorermagazin-de.translate.goog/bauberi/defaus21.htm?_x_tr_sl=auto&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=nui Has got a lot more torque in low revs. But I think it has nothing to do with this problem. I have a 2.5" exhaust its 2.5" from the turbo outlet all the way through - in my 200tdi (with "performance" boxes) - it helps keep the exhaust temps down. 1 Quote Link to comment Share on other sites More sharing options...
western Posted October 15, 2021 Share Posted October 15, 2021 My 200 has the standard TD system minus the first silencer, I haven't had any problems with it. Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted October 15, 2021 Share Posted October 15, 2021 2 hours ago, vulcan bomber said: Gold seal 200TDis are a myth.... Luckily not. Unipart built them up and you can check the engine numbers against the factory records if you know the right person. Not many were done, simply because LR set the bar so high (low) on the 200tdi before they would approve a rebuild - 2litres of oil per 500 miles for example. So no myth - fact... Quote Link to comment Share on other sites More sharing options...
Jocklandjohn Posted October 15, 2021 Author Share Posted October 15, 2021 (edited) On 10/12/2021 at 7:22 AM, muddy said: you have a N/A or turbo diesel air filter, these are smaller than a TDi one, also your intake pipework doesn't seem right with the large silicone pipes, are these home made? if so what ID are they? I think you said you don't but do you have a larger TDi exhaust on there? A friend of mine had a genuine defender 200 in a TD and we never could get it to pull right, unfortunately it got stolen before we could get to the bottom of it. Yes it was a 19J originally, and retrofitted with a 200Tdi. Still uses existing air filter box, and the exhaust is the standard 2.5 system originally fitted (same as Ralph). Intake pipwork is same internal diameter as standard pipes I took off, only difference is I added an additional inlet to the air filter coming from the front wing into a Y just before the air filter housing to ensure sufficient air. But tbh nothing on my vehicle is in any way weird - I've read loads of stuff on here about the various modifications I've made, mainly as suggested or actually done by Vulcan, Ralph, Western, Mo etc and am very conservative when it comes to messing about. And when I've been unsure I've asked for advice!! Edited October 15, 2021 by Jocklandjohn 1 Quote Link to comment Share on other sites More sharing options...
reb78 Posted October 15, 2021 Share Posted October 15, 2021 On 10/12/2021 at 7:22 AM, muddy said: you have a N/A or turbo diesel air filter, these are smaller than a TDi one, Are they? They look almost identical to me, or very similar. Quote Link to comment Share on other sites More sharing options...
monkie Posted October 15, 2021 Share Posted October 15, 2021 7 minutes ago, reb78 said: Are they? They look almost identical to me, or very similar. I've been reading this and wondering. As it happens I have a full 19J setup and a defender 200tdi in my garage. I shall measure both (as well as the exhaust) and post it on here. Quote Link to comment Share on other sites More sharing options...
Jocklandjohn Posted October 17, 2021 Author Share Posted October 17, 2021 Update. Having replaced the lift pump (with added spacer) and now able to get it out for a run (had to replace rear shocks first) things have improved. Hill out of town I would normally find myself slowing considerably on and ending up in 3rd at 35 or 40mph I went up in 4th and was nearly at 50mph so thats much better. It pulls more cleanly on the flat in lower gears and has vastly improved clean (ie less smoke) acceleration in 3rd and 4th. However 5th feels sluggish on acceleration until the turbo cuts in, and the EGT's *seem* to have got a bit higher (I've not adjusted the boost which appears to have dropped slightly since fitting the new lift pump presumably due to the change in fuel delivery). So I'm part way there! The belt is being changed and all the timing (engine & FIP) checked over at the end of this week From my poking about here in previous threads the symptoms I have appear to some extent to be consistent with retarded timing - easy start, smooth running, slightly grey smoke when starting off that soon clears, high-ish EGT's and poor performance, and worse MPG but with an engine that runs cooler - all of which I have to varying degrees. 2 Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted October 23, 2021 Share Posted October 23, 2021 On 10/15/2021 at 1:04 PM, western said: My 200 has the standard TD system minus the first silencer, I haven't had any problems with it. There is no need to have problems to play around 😁 1 Quote Link to comment Share on other sites More sharing options...
Jocklandjohn Posted November 11, 2021 Author Share Posted November 11, 2021 (edited) Update: Timing belt NOT changed yet, but mechanic and his colleague inspected engine & ancilliaries, thought it all looked ok and no obvious visible problems, then took it out for a run with me and agreed it was lovely and smoooth running, but when he booted it we left enough smoke in the village to start a kipper factory. He agreed the hill pulling ability was compromised too, so we removed the air intake and fitted a free-flow filter on the turbo and had another go and it wasn't much better. He then told me to take his 200tdi 110 with standard turbo & slightly tweaked fuel pump and the same Disco gearing, out for a run and I have to say it was a revelation, it pulled like a clydesdale horse and emitted very little smoke and went like a train on the flat and seemed not to even notice the hill I went up. He said he pulls loads of hay in a twin axle trailer using it and easily manages hills, can cruise at 75mph all day pulling it with no effort. So we agreed to take mine back in a week or two and do the timing belt & pump timing and maybe swap out my fuel pump for one he has that he knows works properly to see if that helps. Meanwhile I decided to replace the fuel line and remove the Eberspacher T fuel pick up just before the lift pump. Did that yesterday, one nice new length of rubber fuel hose uninterrupted from tank to lift pump, and when I took it out for a run there was a very marked improvement in performance, but crucially also a reduction in the overall smokiness. Once it was warmed up I took it up the long hill out of town, it slowed in 5th but in 4th it continued to pull pretty well and I was able to maintain 45/50 for most of it though EGT's started to climb over 700. Normally I'd have struggled to maintain 40mph and depending on the wind direction often ended up in 3rd. On the flat its much much sprightlier, I can feel considerably more poke, and when rolling on the throttle in 4th from 20mph it really pulls and when the turbo cuts in you can feel the oomph and it continues all the way to 60, change to 5th and all the way to 70mph with no difficulty though I chickened out on trying to go any faster (but it felt it was able to) . What is VERY noticeable is that the acceleration in 1st and 2nd which previously felt like it had a rev limiter on it and prevented me going above 2000 RPM is now much more vigorous and I easily got to 3kRPM. Conclusion thus far is that possibly the fuel line was partially blocked, or maybe pin-holed, or the Eberspacher fuel take off was causing some problem with the fuel flow. Or a combination of both. So, its helped immensely just changing the fuel line. I'm taking the injectors in for a service next week and renewing the nozzles so will see what addiitonal benefits that brings. I now need to find an alternative fuel pick up point for the Eberspacher... Edited November 11, 2021 by Jocklandjohn 2 Quote Link to comment Share on other sites More sharing options...
