Exmoor Beast Posted January 19, 2007 Share Posted January 19, 2007 I have to replace a wing mirror on my brothers freelander. How does the damn thing come off? I presume the inner speaker grill thingey comes out somehow. I don't want to force it though and snap it off by heaving at it. Will Quote Link to comment Share on other sites More sharing options...
Dr Goon Posted January 19, 2007 Share Posted January 19, 2007 Drive too close to a brick wall. . . . . . . . . [Coat on and making rapidly for the door] Quote Link to comment Share on other sites More sharing options...
Exmoor Beast Posted January 19, 2007 Author Share Posted January 19, 2007 Thanks Gordon. No Help! I did a similar thing last week with a 7.5ton truck, caught a sign at the side of the road and smashed both nearside wing mirrors, cost me £130 Not impressed when they charge you £18 for 'insurance' Ho hum Right back to the problem in hand, Freelander wing mirrors.... Will Quote Link to comment Share on other sites More sharing options...
V8CAMEL Posted January 19, 2007 Share Posted January 19, 2007 Thanks Gordon. No Help!I did a similar thing last week with a 7.5ton truck, caught a sign at the side of the road and smashed both nearside wing mirrors, cost me £130 Not impressed when they charge you £18 for 'insurance' Ho hum Right back to the problem in hand, Freelander wing mirrors.... Will easy peasy. remove the black triangle of plastic on the inside of the door. Undo the bolts ( i think they are TORX bolts) and remove wing mirror from the outside Quote Link to comment Share on other sites More sharing options...
Exmoor Beast Posted January 22, 2007 Author Share Posted January 22, 2007 Does it just pull off this black plastic bit? This one has what looks like a speaker panel directly behind the wing mirror, I haven't looked to see if it is actually a speaker, but its a grill thingey anyway. I gave it tentative tug but it seemed fairly well attached (strange for a Land Rover I know) I wondered if the grill bit popped out then it was screww fixed or something... Will Quote Link to comment Share on other sites More sharing options...
V8CAMEL Posted January 22, 2007 Share Posted January 22, 2007 Does it just pull off this black plastic bit?This one has what looks like a speaker panel directly behind the wing mirror, I haven't looked to see if it is actually a speaker, but its a grill thingey anyway. I gave it tentative tug but it seemed fairly well attached (strange for a Land Rover I know) I wondered if the grill bit popped out then it was screww fixed or something... Will i'm sure it just pops off but cant remember and as i am 160 miles from the freeloader until Saturday cant check sorry Quote Link to comment Share on other sites More sharing options...
DEANO3528 Posted January 22, 2007 Share Posted January 22, 2007 Alright Will? Sounds like a job for someone with a RAVE cd. Quote Link to comment Share on other sites More sharing options...
Andy Posted January 24, 2007 Share Posted January 24, 2007 if its attached with clips anything like disco ones you'll need a long screwdriver & a lot of effort (about when you excpect it to break) to move the thing. probably no help but thought id say it anyway Quote Link to comment Share on other sites More sharing options...
jules Posted February 17, 2007 Share Posted February 17, 2007 it goes up or towards the glass I cant remember which. put some wd40 on the mirror to ease it out.. the rubber seal makes it very tight Quote Link to comment Share on other sites More sharing options...
Blippie Posted February 26, 2007 Share Posted February 26, 2007 if its attached with clips anything like disco ones you'll need a long screwdriver & a lot of effort (about when you excpect it to break) to move the thing. probably no help but thought id say it anyway You need to lever it firmly but carefully from the bottom edge. Then there are two wires behind that attch to the tweeter-thingy. I swapped the non folding mirrors on our ex-Jules Freelander for the later folding type. YOu can get them off internet for £50-75 and it just needs one exterior hole being drilled out to (IIRC) 13mm. 10 minute job. Cheers Blippie Quote Link to comment Share on other sites More sharing options...
