Corrosion - What's the recommended fix?
Hi Folks,
Noticed that we have some corrosion around the rear seating retaining bracket on our Defender 110 - Images below. In particular on the driver's side there is a small hole.
Please could you let us know what are the recommended / suggested ways of addressing this and fixing.
It's a little irritating in that the rest of the bodywork is in excellent condition.
Thanks in advance,
Simon...
That spot is over the steel seat belt mount brace , ideally remove the brace clean the aluminium and bond an aluminium plate over it . Clean and paint the brace and refit with thin plastic as an isolator ( old 5l oil can ) and I usually slap grease in between for some extra protection
Steve
