Defender - fitting wing top chequered plate problem
Defender wing top chequer plate- supplied by John Craddock. If I fit using pre drilled holes and align with the holes for the air  vents the chequer plate goes under the bonnet but there is not sufficient clearance. Whats the best solution?
