300 TDI
Welcome :)
Do you mean the dump valve on the air filter can, or the water drain at the lowest point?
Both of these should be sealed when fitting a snorkel. I filled the water drain with silicone sealant, and I took the dump valve off and replaced it with a little red cap from a 400ml WD40 can, taped on, which is just the right size :)
There's a thread on here somewhere about it, from when I fitted the Safari snorkel...
Thank you all for the replies.
What I meant was the Dump Valve in the air intake hose,and airbox.
I now realise that I need to seal both !
What happens to any rain water if it gets in.
The snorkel is ex MOD complete with a Donaldson airbox and filters.
