Jim Mason Posted November 14, 2021 Share Posted November 14, 2021 Might need help here, never swapped out an engine before but cannot afford garage prices. Im a field service engineer by trade so got tools and knowledge etc. Most of the old engine is stripped ready for removal... Replacement engine photo's attached. Need to do timing belt change what else whilst its out of the engine, financies are tight. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted November 14, 2021 Share Posted November 14, 2021 Are you doing the clutch too ? This guy on YouTube has a lot of 300Tdi’s https://youtube.com/c/BritannicaRestorations Quote Link to comment Share on other sites More sharing options...
Jim Mason Posted November 14, 2021 Author Share Posted November 14, 2021 Been watching his video's, they are a bit addictive... What pins does the engine brackets take, brought new as neither engine has them fitted. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted November 14, 2021 Share Posted November 14, 2021 Do you mean the lifting brackets ? if so both mount to the cylinder head on the 200 and 300 - Ralph (Western) shared some pictures here: 1 Quote Link to comment Share on other sites More sharing options...
Arjan Posted November 14, 2021 Share Posted November 14, 2021 Whenever an engine is out, timing and rear crankshaft seal get done regardless. Clutch is completely replaced. In doubt, slave cylinder is done, too. Once back in. warm the engine up and do a full service 1 1 Quote Link to comment Share on other sites More sharing options...
Jim Mason Posted November 14, 2021 Author Share Posted November 14, 2021 How much is a new clutch for a 300 Tdi Disco 1... Who is the best? Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted November 15, 2021 Share Posted November 15, 2021 Clean the engine Back flush the cooling system P gasket Ancilleries belt Core plugs See if you can find out where all that oil leaked from 1 Quote Link to comment Share on other sites More sharing options...
Jim Mason Posted November 15, 2021 Author Share Posted November 15, 2021 How do i back flush the cooling system? What methods work? Started cleaning the engine down yesterday with Diesel, most of the muck was coming off... Seems most of it is road film, engine never lost any oil according to previous owner and belives it came from else where... prop shaft seal etc. Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted November 16, 2021 Share Posted November 16, 2021 Hose pipe in all the coolant orifices - if you do this when changing the P gasket - you avoid getting lots of crud in the water pump housing Don't use Diesel, use gunk or similar Quote Link to comment Share on other sites More sharing options...
Jim Mason Posted November 16, 2021 Author Share Posted November 16, 2021 Where can i get some from at the right price? Use Diesel as i get it from work on the sly, shifts through the crud with ease Quote Link to comment Share on other sites More sharing options...
Peaklander Posted November 16, 2021 Share Posted November 16, 2021 Google the Gunk, as it’s available widely. I think it’s even available mail order. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 16, 2021 Share Posted November 16, 2021 Traffic film remover is wonderful stuff..... Oxalic acid in the cooling system is fantastic and cheap on ebay, often sold as wood bleach. 2 2 Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted November 17, 2021 Share Posted November 17, 2021 If you look at it and go through , in your head, everything minor that can go wrong, be a pita and should be part of the regualr maintenance programme. Replace nuts and bolts that look iffy, jubilee clips etc - and make a list of what you didn't change that you need to change as and when you have some readies 1 Quote Link to comment Share on other sites More sharing options...
Jim Mason Posted November 22, 2021 Author Share Posted November 22, 2021 On 11/16/2021 at 11:56 PM, Bowie69 said: Traffic film remover is wonderful stuff..... Oxalic acid in the cooling system is fantastic and cheap on ebay, often sold as wood bleach. So the Oxalic Acid is a rust remover, can this be used once the engine is back in and running. Presume traffic film remover is to clean the block... Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 22, 2021 Share Posted November 22, 2021 Yep, works great with the engine running , as it gets everywhere and the heat helps it work. And yes, TFR for the oily outside 1 1 Quote Link to comment Share on other sites More sharing options...
Jim Mason Posted November 28, 2021 Author Share Posted November 28, 2021 Weather gone nasty on me, need to work on engine in garden umder a gazebo. I know from previous jobs if its too cold you cannot work on metal as it needs to be a certain temperature. What are everyones views on this... Engine is outside, covered up, how long can i leave it like this? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 28, 2021 Share Posted November 28, 2021 1 hour ago, Jim Mason said: I know from previous jobs if its too cold you cannot work on metal as it needs to be a certain temperature. It is never too cold to work on engines -even to the point of scraping ice off the tools, you just need to work harder to maintain circulation. 1 hour ago, Jim Mason said: Engine is outside, covered up, how long can i leave it like this? Depends how disassembled it is, whether you have plugs all orifices (plastic bag and cable tie round inlet, get creative with anything else that means moisture can get in), and how well covered it is. Personally I'd just get on with it and get it in there and running Quote Link to comment Share on other sites More sharing options...
Jim Mason Posted November 28, 2021 Author Share Posted November 28, 2021 Thats what were doing, just ordered a 3m x 3m gazebo, and portable gas heater. Going to lay boards down on the grass and strip it to hell 1 Quote Link to comment Share on other sites More sharing options...
Jim Mason Posted December 4, 2021 Author Share Posted December 4, 2021 Things you find in the sump... what part of the engine is this... Quote Link to comment Share on other sites More sharing options...
Jim Mason Posted December 4, 2021 Author Share Posted December 4, 2021 Quote Link to comment Share on other sites More sharing options...
Jim Mason Posted December 4, 2021 Author Share Posted December 4, 2021 S9 is that what a p gasket looks like lol... Serviced by landrover, me thinks not... cowboys are us... Well soon be sorted and fitted to landy Quote Link to comment Share on other sites More sharing options...
steve b Posted December 4, 2021 Share Posted December 4, 2021 was that cam belt loose when you took the cover off? Steve Quote Link to comment Share on other sites More sharing options...
Jim Mason Posted December 4, 2021 Author Share Posted December 4, 2021 Engine came with no injection pump... Quote Link to comment Share on other sites More sharing options...
Jim Mason Posted December 10, 2021 Author Share Posted December 10, 2021 Moving on, cold working on engine outside... Few more horrors found in this engine ive obtained, engine not had any anti freeze in lots of corrosion present, removed core plugs to find silicon and remains of a gasket. All slowly being cleaned & replaced Quote Link to comment Share on other sites More sharing options...
Jim Mason Posted December 10, 2021 Author Share Posted December 10, 2021 Quote Link to comment Share on other sites More sharing options...
