treebloke Posted November 15, 2021 Share Posted November 15, 2021 I have a 2009 model and every time I start it the air con comes on, I turn it off and put the heater but when I stop the car when I restart it the air con is on again. Its not a problem in the summer but now its dropped cold its a nuisance. Has anyone else had the same scenario?. Quote Link to comment Share on other sites More sharing options...
Implandy Posted November 15, 2021 Share Posted November 15, 2021 Don't know this model but do you perhap have the airflow directed to the screen? maybe the demist function is on? Quote Link to comment Share on other sites More sharing options...
treebloke Posted November 20, 2021 Author Share Posted November 20, 2021 I've tried moving everything and resetting each and every knob and dial. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted November 24, 2021 Share Posted November 24, 2021 You should leave the a/c on constantly as the car has climate control so either heats or cools depending on what it is asked for. If it is cooling when you are asking for heat then you have an issue ( obviously!). Can you get her plugged in to see if any faults are logged? 1 Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted November 24, 2021 Share Posted November 24, 2021 2 hours ago, bishbosh said: You should leave the a/c on constantly as the car has climate control so either heats or cools depending on what it is asked for. If it is cooling when you are asking for heat then you have an issue ( obviously!). Can you get her plugged in to see if any faults are logged? I am in agreement. With Range Rovers after the P38 the first point of call has to be the computer as almost eveything on them refers back to it. Quote Link to comment Share on other sites More sharing options...
treebloke Posted December 16, 2021 Author Share Posted December 16, 2021 On 11/24/2021 at 6:03 PM, bishbosh said: You should leave the a/c on constantly as the car has climate control so either heats or cools depending on what it is asked for. If it is cooling when you are asking for heat then you have an issue ( obviously!). Can you get her plugged in to see if any faults are logged? Had it plugged in and no faults. I just find it strange you can't turn the a/c off and it stays off? It does get warm or cold whichever setting to tell it you want so I guess I will learn to live with it. Other than that its a really nice car. Quote Link to comment Share on other sites More sharing options...
L19MUD Posted December 17, 2021 Share Posted December 17, 2021 15 hours ago, treebloke said: Had it plugged in and no faults. I just find it strange you can't turn the a/c off and it stays off? It does get warm or cold whichever setting to tell it you want so I guess I will learn to live with it. Other than that its a really nice car. They all do this as standard. I never turn mine off as even when the car is heating the air not cooling it, it is always also working as a dehumidifier and stopping the windows steaming up I don't remember my 2002 L322 doing it but all 2007 on TDV8's do it and the later 2010 on facelifted ones too Quote Link to comment Share on other sites More sharing options...
missingsid Posted December 17, 2021 Share Posted December 17, 2021 1 hour ago, L19MUD said: They all do this as standard. I never turn mine off as even when the car is heating the air not cooling it, it is always also working as a dehumidifier and stopping the windows steaming up I don't remember my 2002 L322 doing it but all 2007 on TDV8's do it and the later 2010 on facelifted ones too My D3 would steam up if left on recycle IIRC the manual stated don't do it for long periods. Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted December 18, 2021 Share Posted December 18, 2021 We used to have a Honda civic that did this. If the vents were set to demist the air con came on automatically when you started the car (no fancy climate control involved). Drove me up the wall! I don't mind air con switching on when I switch to demist, but if I choose to turn it off it should stay off... Quote Link to comment Share on other sites More sharing options...
missingsid Posted December 18, 2021 Share Posted December 18, 2021 8 hours ago, geoffbeaumont said: We used to have a Honda civic that did this. If the vents were set to demist the air con came on automatically when you started the car (no fancy climate control involved). Drove me up the wall! I don't mind air con switching on when I switch to demist, but if I choose to turn it off it should stay off... But car aircon works by removing the moisture from the air so it demists quicker when on. Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted December 18, 2021 Share Posted December 18, 2021 Technically a side effect of how it works, but yes, it does and it therefore makes some sense to turn it on when switching to demist. What about if you just want cool air directed at your face? I usually have the screen vents on for this, without my hands getting blasted with cold air, and I don't usually want it cold enough to need air con unless it's hot outside. I much prefer the system on my current car, which has a separate demist button which directs all air to the screen vents, activates air con and sets a minimum temperature and fan speed. Just turning on the screen vents is just... turning on the screen vents. Quote Link to comment Share on other sites More sharing options...
missingsid Posted December 19, 2021 Share Posted December 19, 2021 3 hours ago, geoffbeaumont said: Technically a side effect of how it works, but yes, it does and it therefore makes some sense to turn it on when switching to demist. What about if you just want cool air directed at your face? I usually have the screen vents on for this, without my hands getting blasted with cold air, and I don't usually want it cold enough to need air con unless it's hot outside. I much prefer the system on my current car, which has a separate demist button which directs all air to the screen vents, activates air con and sets a minimum temperature and fan speed. Just turning on the screen vents is just... turning on the screen vents. Ah get it. Quote Link to comment Share on other sites More sharing options...
