RLF Posted January 17, 2022 Share Posted January 17, 2022 2003 Freelander, the main brake lights, (not the ones on the bumper nor spare wheel), do not work. All other lights work, including headlight/red tail lights (same bulb). I've checked the bulbs, the connections for continuity, etc. in the rear, and the fuses, all good. So either a wire is broken somewhere up front, before where the wires split to go left and right, or something completely different. I have no idea where to look for those wires up front of the vehicle. As an aside, I'm also having tailgate window regulator issues due to battery disconnection, but I suspect that is an independent issue. Thank you Quote Link to comment Share on other sites More sharing options...
smallfry Posted January 19, 2022 Share Posted January 19, 2022 Is the centre brake light on the spare wheel also not working ? If not, I would look at the switch on the brake pedal Quote Link to comment Share on other sites More sharing options...
