Changing brake pipes - parts and tools required
I am going to change my front brake calipers on my 1993 defender with 200tdi axles, and I require advice on the tools and parts I need, so could you help with the following please;
Firstly,  what size brake pipe spanner do I need?
Second,  what size brake pipe do I need and what length.  How many fittings will I  need. Does anyone have a link to a reasonably priced decent set.
Third, any advice on a flaring tool for the pipe. If they are a reasonable price I may buy one, otherwise I may try to borrow one as how often should I need it?
And finally,  flexible brake hoses. The original ones don't seem too expensive but I have also seen the braided ones. What would you recommend? Are the braided ones better and worth the extra cash. If the braided, a link to reasonably priced ones would be helpful.
As always, your help and advice is appreciated.
Mick
PS - I am looking to change the brake lines as I suspect they may well brake when removing them as they are quite crusty!!
Edited by Mossberg
This tool is excellent and does lovely flares - https://www.carbuilder.com/uk/hand-held-brake-pipe-flaring-tool
brake pipes are 3/16" and I buy cupronickel in a roll from Automec along with the fittings. I cant remember what fittings are needed off the top of my head but look at the website and the car and you will work that bit out.
for the flexi, I dont know - all of the afternarket stuff risks issues. I'm sure Jeff on here had Britpart ones where they failed to make a hole down the centre for the brake fluid! I think the ones on the 110 are Allmakes. But see what other's recommend now (BP owns Allmakes IIRC so god knows what they quality of either is like now).
how much are genuine flexi pipes? Might be safest...
  • Like 1
Also, if you are replacing it all, while the calipers are off, slot the brackets on the top of the hub that hold the end of the hose. That way you can just loosen the locknuts holding the  hoses and lift  the hose out of the bracket and the caliper out of the way without disconnecting if you have to attend to a swivel for instance.
  • Like 2
Guys this is great info  many thanks.
There are lots of the "in situe" pipe flaring tools on the bay, are they all pretty much the same? (they certainly look it)
Regarding the fittings,  would you recommend steel,  stainless or brass?
Personally I would avoid steel. I normally use Cunifer pipe with brass fittings (Automec) - they seem to be reasonably corrosion free, ok a bit of verdigris. If you go for the Goodridge type hoses, I suggest get all stainless. These parts all usually get salt sprayed from time to time. I also use either brass or stainless bleed nipples.  But this is a personal thing, someone else may have completely different ideas and reasons.
Many thanks, I think I will try to go for brass where I can (I am always cautious of stainless binding).
I will look into the braided hoses. I did consider britpart as its about £25 for a set, but people have raised issues with these - was this in the past or is it ongoing?
It's very difficult. I've had Britpart hoses and cylinders on the 109 for two decades, all fine. On the other hand the Britpart light fittings broke up two days after fitting.
Buy genuine from Blanchards if in doubt. It's brakes, be doubtful.
On steel v non ferrous. The steel will last ten to fifteen years then fail just as you need to service them. Unless you apply anti corrosion, like copper slip or under body wax.
I'd fit the Goodrich hoses. In fact, I did.
Many thanks folks, I will look for some Goodrich ones.
One more question,  do the braided hoses make a difference?
Sorry for all the questions but I  want to make the right choices but can't afford to squander my cash (as then I can't afford to do the next bit!!
As an alternative to all this flaring and bending, I did my entire truck in stainless braided TFE hose from Think Automotive, it's not cheap but I much prefer it - you can cut out a lot of joins, you can route it easily, and there's no faffing about flaring ends. Just a thought.
Second that about Llama 4x4 you could get complete hose kit made up to save any faffing with a flaring tool. something like this https://llama4x4.com/product/land-rover-extra-long-braid-front-brake-hoses-1-65m-to-run-up-the-radius-arms/.  I have got his rear axle kit to fit
Also you can swap the fitting on the front callipers to a banjo fitting on the flexi pipe, which then does away with the small copper pipe on to of the swivel housing making changing wheel bearings and swivels easier as the calliper just lifts out the way. There is a thread on here somewhere about it.
An expensive way of doing it but Pioneer do full  brake hose kits but i think are more pricey than llama. https://www.pioneer4x4.com/products/full-brake-line-kits/land-rover/defender-90-land-rover/
If you are likely to be doing more then buy a good flare kit as i have used cheap and they are infuriating. I borrowed a mates proper kit and it was lovely and easy to use mounted in a vice. Gwyn lewis has a good way of making brkae pipes nice and neat I wish i had seen it before rebuilding my 90 https://www.facebook.com/watch/?v=1575241232635104
Jon
  • Like 1
