Mystery item inside front door !
Evening All, just seen this post and I have the exact same plastic parts sitting on my work bench after taking the front door cards off my 2002 110. Both were found in the bottom of the doors and I am still looking where they should be returned to!!!
So watching this with interest….
Toby
What are the dimensions?  Is the trough the same length as the width of the window?  Is the length of the "drain leg" the same as the distance of the bottom of the window, when in the down position, to the bottom of the door?  If the answer is "Yes" to either of the last two questions it gives an indication of where to look for previous attachment.
Mike
