110 300tdi rear brakes - bolts required to fit caliper bracket (FTC3306) (& Stub axle)
hxk494
Hi folks,
I'm doing some work to my 110 brakes and need to replace the caliper brakcet - ftc3306 - I've fitted the new one using the existing bolts and I'm pretty sure these are wrong and should be longer as they don't come all the way through the threaded part of the bracket. It looks like they should be closer to 45mm in length rather than the 35mm that was in.
Looking again at the parts fiche it appears that on the 110 the stub axle/calper bracket should be attached (per side) with 4 of M10 x 55 bolt (BX110111L) and 2 of M10 x 35 (BX110071M) and 2 of NY110047L M10 Nylock. This would thefore be 2 shorter bolts and nuts and the 4 longer ones going into (through) the caliper bracket but without nuts.
Would anybody be able to confirm if this is correct? Serial is VA if that makes any difference
I've attached a few photos which show the 35mm failing to fill the 4 threaded holes in the caliper bracket (but this is how it was attached previously).
Thanks, Martin.
20 hours ago, western said:
As the 110 parts book shows BX110111L M10 x 55mm IIRC thats what I used on my drum to rear disc conversion using the FTC3306 caliper brackets I can't remember if I put nuts on them or if they are just beyond the caliper bracket face.
thanks @western, will order BX110111L but I'm not convinced that's going to work with the unthreaded section of the bolt being the length it is but will give it a try.
