slayor2005 Posted January 25, 2022 Share Posted January 25, 2022 Can anyone tell me what Relay i need to put into the system between the rear heated window and the switch via a fuse ( 15amp ) but this keeps blowing after about 20/30 seconds. Thanking you in advance Slayor 2005 Quote Link to comment Share on other sites More sharing options...
western Posted January 25, 2022 Share Posted January 25, 2022 Which vehicle & year ? Quote Link to comment Share on other sites More sharing options...
slayor2005 Posted January 25, 2022 Author Share Posted January 25, 2022 Its a Defender 90--1988 200TDI Engine is about a 1990 replacement and the rear window is brand new with a Autosparks loom Quote Link to comment Share on other sites More sharing options...
western Posted January 25, 2022 Share Posted January 25, 2022 heated rear screen relay & voltage sensitive switch [yellow case] lives in right front corner of dash, behind & to right of instrument pack & roughly inline with the 3 switches between door & steering column. IF you have replaced the main/dash loom with the correct loom that has heated rear screen & rear wash/wipe, it will have the rear sockets included. Quote Link to comment Share on other sites More sharing options...
hurbie Posted January 25, 2022 Share Posted January 25, 2022 do you use decent quality fuse's ? the old 110's say 20A in the fusebox lid Quote Link to comment Share on other sites More sharing options...
slayor2005 Posted January 26, 2022 Author Share Posted January 26, 2022 Ok you two i will look into your answers and see what i can find. Thanking you 1 Quote Link to comment Share on other sites More sharing options...
