Cchase Posted January 25, 2022 Share Posted January 25, 2022 These spacers are on my series 3 109" frame to hold the bump stops. Are they a specific item for military frames or a regular item on 109 frames? Are they necessary if they are not on regular 109 frames? Thanks, Colin Quote Link to comment Share on other sites More sharing options...
Gazzar Posted January 25, 2022 Share Posted January 25, 2022 They extend the bump stops for vehicles with longer than standard shackles, like the one tonne vehicles and some military vehicles. They can be removed if you have standard shackles and springs. Or you are willing to risk the springs doing weird things ( braking for multi-leaf springs) under extreme articulation. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted January 25, 2022 Share Posted January 25, 2022 You should have extended spring mounts on the chassis to match the extended shackles. A photo of the front dumb iron would confirm. Quote Link to comment Share on other sites More sharing options...
Cchase Posted January 25, 2022 Author Share Posted January 25, 2022 Front dumb iron and shackle from rear of front spring. So I guess I could go shorter shackle on the back and upper hole on the front if I wanted to delete the spacers. Would that be a step backward? Thanks. Quote Link to comment Share on other sites More sharing options...
Snagger Posted January 26, 2022 Share Posted January 26, 2022 If you don’t have those bump stop extenders, then the dampers could be damaged by over compression. Some modern dampers now have internal stops, so it would be less critical, but I’d still recommend keeping them. On a 1-Ton, they would also help prevent the 9.00 tyres from contacting body panels. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted January 26, 2022 Share Posted January 26, 2022 I'd keep them. They aren't expensive. Quote Link to comment Share on other sites More sharing options...
Cchase Posted January 26, 2022 Author Share Posted January 26, 2022 3 hours ago, Gazzar said: I'd keep them. They aren't expensive. 22 pounds each on John Craddock! Mone are rebuildable. Just need the tabs refreshed. Cheers, Colin Quote Link to comment Share on other sites More sharing options...
Snagger Posted January 26, 2022 Share Posted January 26, 2022 Using the upper holes and standard shackles would give you a ride heigh a little above a standard 109 if you retain the parabolics - they typically raise a vehicle by 1-2” at the front and 2-3” at the rear , but that does vary with brand and vehicle weight. The 1-Ton system will raise it another 1.5” or so. You can use the same springs either way. Which is best depends on your own circumstances. The lower height is easier to load or enter and is probably slightly easier to find parts like dampers and brake lines for. The taller arrangement gives more ground clearance and allows taller tyres (be wary of over gearing the engine), but can also make parking more restricted where there are height restrictions. 1 Quote Link to comment Share on other sites More sharing options...
