defender dinky Posted February 1, 2022 Share Posted February 1, 2022 Hi all, looking for part number for a range rover classic powersteering to alternator belt, range rover classic 1988, 3.5 efi auto, bought two so far both companies saying yes this will fit but they don't one was to long regardless of adjustment on the alternator, other one belt was to wide for the v pullies wouldn't seat right it was just sliding round eventually burnt the sides of the belt warped then snapped, there wasn't any teeth on the original belt, like the new one's, dd Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 1, 2022 Share Posted February 1, 2022 What does the writing say on the back of the old belt? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 1, 2022 Share Posted February 1, 2022 As Bowie says, belts have a code on them that is basically cross section shape and length in millimetres. Any motor factors should be able to match the original if you show it to them and don't tell them what it's from or give them a registration. 1 Quote Link to comment Share on other sites More sharing options...
western Posted February 2, 2022 Share Posted February 2, 2022 You might be able to find a suitable vee belt in here https://www.gates.com/us/en/power-transmission/v-belts/bandless-v-belt.html Quote Link to comment Share on other sites More sharing options...
defender dinky Posted February 2, 2022 Author Share Posted February 2, 2022 I'm afraid the belt didn't come with the truck, it was bought as a project, 12mth ago, dd Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 2, 2022 Share Posted February 2, 2022 Vey another old belt, wrap it round, cut it to length, measure and take to the parts shop. 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 2, 2022 Share Posted February 2, 2022 P.s. the reply editor is screwing up pretty well on mobile foe me, at the moment.... Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 2, 2022 Share Posted February 2, 2022 2 hours ago, defender dinky said: I'm afraid the belt didn't come with the truck, it was bought as a project, 12mth ago, dd A length of string and a tape measure does the job - wrap it round the pulleys in the route the belt would take, then lay it out & measure the length. Width-wise I think it's pretty much 8mm, 10mm, 13mm from memory... the gates belts catalogue will give you a fair idea if you find the nearest length and size that sounds sensible. 1 Quote Link to comment Share on other sites More sharing options...
defender dinky Posted February 3, 2022 Author Share Posted February 3, 2022 Found the belt 10mmx670, that allows for adjustment on alternator, it's a dayco, are these descent, dd 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 3, 2022 Share Posted February 3, 2022 Yes. Quote Link to comment Share on other sites More sharing options...
western Posted February 3, 2022 Share Posted February 3, 2022 Dayco & Gates are factory fit, both good quality makes. Quote Link to comment Share on other sites More sharing options...
defender dinky Posted February 4, 2022 Author Share Posted February 4, 2022 Sorted then, dd Quote Link to comment Share on other sites More sharing options...
