nileseh Posted February 6, 2022 Share Posted February 6, 2022 Okay, I give up. I have a ex MoD 110, around 1986 I think, with RH steering and I've not yet changed the headlights over to LH steering for the US. I can't see how to get the things out of the car. There is a black ring, the parts manual calls it a "ring, mask" that in is the way of the screws that hold the headlight in place. there are a number of screws that are attached to this ring, none of which seem to hold it in place. The three on the face must be to hold perhaps the "mask" in place, then 3 others that don't seem to do anything at all. they screw into separate bosses that don't seem to be attached to anything. How does this thing come apart? Quote Link to comment Share on other sites More sharing options...
hurbie Posted February 7, 2022 Share Posted February 7, 2022 a picture would be helpfull . Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted February 7, 2022 Share Posted February 7, 2022 If it's military fitment it might be as simple as pushing the light in and twisting, cannot remember whether it's right of left, if it is this type you should be able to see some small springs x 3 around the headlight ring and some elongated holes, once twisted around to align with larger hole diameter the headlight will just pull off and you will gain access to screws underneath regards Stephen Quote Link to comment Share on other sites More sharing options...
nileseh Posted February 8, 2022 Author Share Posted February 8, 2022 Brilliant! Push in and rotate it is. CCW rotation. Of course. In the Royal Army the chaps can't be bothered with messing with little screws that fix the reflector in place. They spare the entire assembly so when an errant rock or sniper shot renders the headlight unservicable it can be replaced on the fly with a push and twist. Very nice. Quote Link to comment Share on other sites More sharing options...
missingsid Posted February 8, 2022 Share Posted February 8, 2022 5 hours ago, nileseh said: Brilliant! Push in and rotate it is. CCW rotation. Of course. In the Royal Army the chaps can't be bothered with messing with little screws that fix the reflector in place. They spare the entire assembly so when an errant rock or sniper shot renders the headlight unservicable it can be replaced on the fly with a push and twist. Very nice. Except in battle they don't use lights at all! Kind of dangerous. The twist and remove system (military might be a bit different) was on British cars as standard for 7 inch headlights, when we still made our own cars. Second sarcastic comment, what's a Royal Army! We have the British Army but the only Royal ones are the nobs in Buck Palace who are pretend heads not actual leaders. Quote Link to comment Share on other sites More sharing options...
nileseh Posted February 9, 2022 Author Share Posted February 9, 2022 Yes, of course, no lights. That's the light switch position clockwise. Silly me. I've not seen the push-twist head light before. It's a good system, do you recall what cars used it? I've had Minis, MGs, Jaguars, Land Rovers all with 7" lights. I stand corrected and apologize. British Army. But then what do we know here? I don't even know how to shift this thing with my left hand. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
Mossberg Posted February 10, 2022 Share Posted February 10, 2022 13 hours ago, nileseh said: I stand corrected and apologize. British Army. But then what do we know here? I don't even know how to shift this thing with my left hand. Don't worry about the Royal//British Army reference. The army is split into different regiments etc and it is these that hold the "Royal" part in their title. Hope all goes well with your lights. Mick Quote Link to comment Share on other sites More sharing options...
missingsid Posted February 10, 2022 Share Posted February 10, 2022 16 hours ago, nileseh said: Yes, of course, no lights. That's the light switch position clockwise. Silly me. I've not seen the push-twist head light before. It's a good system, do you recall what cars used it? I've had Minis, MGs, Jaguars, Land Rovers all with 7" lights. I stand corrected and apologize. British Army. But then what do we know here? I don't even know how to shift this thing with my left hand. Thanks for the help. Only joshing you, if I talk about another country I am sure there is loads I can be teased for. It was just too easy. I don't know the system you have, what I saw on military vehicles was the same as all the above you mention so I could be miles off. If I am then feel free to roast me. Quote Link to comment Share on other sites More sharing options...
