bushwhacker Posted February 8, 2022 Share Posted February 8, 2022 My hazards / four way flashers when turned on will only work if the indicator stalk is on the right side signal position with the ignition on or off. Don't know what to look at indicator stalk maybe ? I did have a new stalk but it got used on my fixer up and its long gone. Regards Mark. Quote Link to comment Share on other sites More sharing options...
Junglie Posted February 8, 2022 Share Posted February 8, 2022 Hi Mark, There's another thread about this somewhere that I had to read when mine went Pete Tong. But basically the flasher earths through the "other" side - indicate left and the right side acts as earth and vice versa. I think. That suggests there's maybe a problem with the right earth as putting the switch right would make the ralyn use the left earth. Do the indicators work OK? (Caveat - it's late and it's been a long day. I may be talking billhooks) Quote Link to comment Share on other sites More sharing options...
Junglie Posted February 8, 2022 Share Posted February 8, 2022 Found it: Some of the pictures are missing but I think they reappear later (or are linked) Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted February 8, 2022 Author Share Posted February 8, 2022 Thanks for the reply information. Must get the kettle on and breakout the digestives. (Had a quick look at the link.) I actually thought that fault would have been a new one so I didn't even search it should have known better. I may be talking billhooks, I do that all the time. Regards Mark. Quote Link to comment Share on other sites More sharing options...
