Transfer case location?
4 minutes ago, Retroanaconda said:
Yes different propshafts, floor plates, seat box and transmission tunnel. There is about a 2” difference in fore/aft position for the transfer box.
The rear of a V8 is completely different to a Tdi
Sorry I ment location/distance only. Was the rear of the V8 same or different to the 300Tdi rear. Ie bolt up to bell housing location.
This may help (copied from another thread):
finally i have a fairly good list for coil sprung land rovers. All measurement are approx standard working length flange to flange:
defender
4 cyl/200tdi: 90 front 667 rear 667 110 rear 1055 130 rear 1480
300tdi/ td5 upto 02: 90 front 627 rear 712 110 rear 1080 130 rear 1520
post 02 td5 rover rear axle: 90 front 627 rear 712 110 rear 1170 130 rear 1600
V8: 90 front 627 rear 712 110 rear 1080 130 rear 1520
tdci: 90 front 700(bearing slip joint phasing can't be changed) rear 650 110 rear 1110 130 rear 1540
discovery I/II
all: front 637(td5 double carden) rear 887
range rover classic
V8 borg warner t-box: front 688 rear 885
LSE: front 637 rear 1080
V8/VM/200/300tdi: front 637 rear 887
hope this helps others if any are incorrect let me know.
mike
  • Like 2
On 2/9/2022 at 10:41 AM, miketomcat said:
Possibly because the heads clash with the foot wells. Certainly this would be the case with a 200tdi, TD and n/a as all are quite close to the bulkhead. The 300 is quite a bit further forward though.
Mike
I wonder if the 300 position was to make it the same bellhousing as the discovery?
