Phill S Posted February 17, 2022 Share Posted February 17, 2022 Anybody able to provide a link to a pdf version of the V8i overhaul manual mentioned in the workshop manual? Thanks - Phill Quote Link to comment Share on other sites More sharing options...
teabag Posted February 17, 2022 Share Posted February 17, 2022 There u go. https://legionlandrover.com/manuales/manual de taller discovery (95).pdf Quote Link to comment Share on other sites More sharing options...
Phill S Posted February 17, 2022 Author Share Posted February 17, 2022 Ok - many thanks - but... If you look on page 129 of that pdf file, that takes you to Flexible Drive Plate and Ring Gear, which under Remove, item 2. Says "see V8i overhaul manual" which doesn't seem to be in the workshop manual itself, but a separate manual? Or am I being thick..... Quote Link to comment Share on other sites More sharing options...
elbekko Posted February 18, 2022 Share Posted February 18, 2022 If you don't need the PDF version, the overhaul manual should be in the RRC/D1 RAVE (this is the old .exe version): http://rave.stringsandints.com/Discovery - Freelander - RR Classic.rar Quote Link to comment Share on other sites More sharing options...
Phill S Posted February 18, 2022 Author Share Posted February 18, 2022 Looks like what I'm after is in there - thanks! Quote Link to comment Share on other sites More sharing options...
