sorgini Posted March 1, 2022 Share Posted March 1, 2022 Hi, after changing my clutch at my 300 tdi, the input shaft maybe at the clutch splines , i torqued some bolts from the gearbox bell housing to enginge and dont realised that the shaft slipped in.I greased it with some copper grease. After loosen bolts and spin a bit the crankshaft bolt it slipped in.So it is possible that i dammaged the input shaft or the clutch? Quote Link to comment Share on other sites More sharing options...
simonb Posted March 1, 2022 Share Posted March 1, 2022 The only way to tell is to take the gearbox off again and check the splines on the clutch plate and input shaft. Or put it all back together and check the clutch works - can you select all the gears with the engine running? Quote Link to comment Share on other sites More sharing options...
