Defender Newb Posted March 19, 2022 Share Posted March 19, 2022 Just spotted that one of the pipes from the back of the water pump seemed to be blocked. 😱 What confuses me even more is that when I cleaned the gunk out there isn’t actually a hole from what I can see anyway. 🤷🏼♂️ It appears to be solid dead end with no waterway unless it’s just the angle I was looking at it. Haven’t pulled out the manuals yet, so thought I would put it out there. Engine may have been cobbled together from 3.5 and 3.9 bits if that makes any difference. 🤷🏼♂️ Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 19, 2022 Share Posted March 19, 2022 They re-used the casting from an earlier version, I think those have a core plug in them although yours may want a new one judging by the amount of crust. Quote Link to comment Share on other sites More sharing options...
Defender Newb Posted March 19, 2022 Author Share Posted March 19, 2022 Ah. Ok. Was thinking if it caused an issue it would have raised its head by now. There was an active water pipe connected to it though, don’t get why it would be connected. I’m assuming that both outlets on the back of the pump were water out? Any benefit to swapping it out or better as is with one blocked? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 20, 2022 Share Posted March 20, 2022 18 hours ago, Defender Newb said: There was an active water pipe connected to it though In that case I've no idea - you need a parts guru for that one. Quote Link to comment Share on other sites More sharing options...
Defender Newb Posted March 20, 2022 Author Share Posted March 20, 2022 Ok. Thanks. Will see what I can dig up. 👍🏻 Quote Link to comment Share on other sites More sharing options...
