kevin50 Posted March 21, 2022 Share Posted March 21, 2022 Thought Id put he rear shocks on today, but as usual theres always a problem . Passenger side seems ok in first pic but on drivers side the bolt is not long enough to go through, dont know why , is it just a case of a longer bolt, or is there something wrong here ?? Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted March 21, 2022 Share Posted March 21, 2022 11 minutes ago, kevin50 said: Thought Id put he rear shocks on today, but as usual theres always a problem . Passenger side seems ok in first pic but on drivers side the bolt is not long enough to go through, dont know why , is it just a case of a longer bolt, or is there something wrong here ?? Probably just needs the new rubber bushes compressing, see if you can force it in until nut can be wound into thread and then nip up regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
sean f Posted March 22, 2022 Share Posted March 22, 2022 Looking at the picture, I am guessing new springs as well??. With new springs and no weight on the back end (engine is in I assume from the exhaust) the shocks could well be at there maximum extension, if they are they will not allow the bushes to sit in fully, try sitting on the back of the chassis when you fit them it might be enough. Also as above the bushes will compress quite a bit. Final point both bolts should be the same length, I expect you have checked that already but worth making sure. Quote Link to comment Share on other sites More sharing options...
missingsid Posted March 22, 2022 Share Posted March 22, 2022 I don't know if there are different sizes of rubber bush but I had items from different makers which are slightly different sizes. Some would not compress enough as the beveled side was a steeper angle? Quote Link to comment Share on other sites More sharing options...
kevin50 Posted March 22, 2022 Author Share Posted March 22, 2022 16 hours ago, sean f said: Looking at the picture, I am guessing new springs as well??. With new springs and no weight on the back end (engine is in I assume from the exhaust) the shocks could well be at there maximum extension, if they are they will not allow the bushes to sit in fully, try sitting on the back of the chassis when you fit them it might be enough. Also as above the bushes will compress quite a bit. Final point both bolts should be the same length, I expect you have checked that already but worth making sure. Checked the bolts and here is the problem. just Assumed that when you order a full kit they should send the correct parts in that kit. 1 Quote Link to comment Share on other sites More sharing options...
