Anyone know anything about Inverters
Hi guys
Today after fitting and wiring in the split charge system we fitted and connected up the inverter ( series 2a overlander ) and although everything works fine for some reason even with the display being bright the lettering / numbering seems dim where as when we first set it up and switched it on you could easily see the lettering / numbering, any ideas please ☹️
12 hours ago, smallfry said:
No idea, but does it have a day/night setting ? Brighter in the day, darker at night.
No it doesn't but after its been on a while you can read it quite easy, it may also because its fitted on its side inside the aux battery box so may take while to sort itself out, not ideal but can deal with it
3 hours ago, Bowie69 said:
Been cold recently, yes?
LCDs really don't like it, suspect you fitted it and while it was warm it was fine, then as the weather took hold it has got worse.
Are yes i never thought of that, that's probably what it is as it was a fairly warm day on Saturday but by the time we got to testing it it did go abit chillie 👍
  • 3 weeks later...
