Gearstick twisting
Paddy_SP
The gearstick on my 300 Tdi D1 has just started turning on its own axis - swivelling, in other words, whenever I change gear. The gears themselves change nicely, but the stick seems to have a mind of its own, and half the time it bashes up against the sides of the tunnel due to the misalignment. I know how to get into the top of the mechanism, but can't visualise what's causing it. Has anyone here any ideas so that I can prep everything beforehand to minimise the amount of vehicle downtime?
As ever, any help would be most appreciated!
I have on other vehicles, the damper at the bottom of the stick becomes unbounded and starts to waggle around.
Think the answer is a new stick, but do check what's going on behind the gaiter.
Thanks - I haven't had an upper gaiter on the stick for years, so I can see that the problem is below the lower one. I suspect that you might be right about there being a broken guide pin - if I didn't have a bleddy Healey Sprite (my wife's) in bits on top of my spare LT230, I'd have been able to take a close look at that!
