Hawklord Posted April 4, 2022 Share Posted April 4, 2022 The rear door on my 300TDI Defender creaks very badly when opening and closing and there is a lot of movement in the hinges. Two options are to replace the hinge pins and bearings or buy new hinge kit but the price difference between the two is around £50. Will just changing the pins etc cure the problem or do the hinges themselves wear, bearing in mind that they are probably the original hinges now being 28 years old. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted April 4, 2022 Share Posted April 4, 2022 Some lubrication should cure the creaks, however all the components wear and after 28 years I wouldn't be complaining too much about having to replace them especially if you can get another bunch of years out of them regards Stephen Quote Link to comment Share on other sites More sharing options...
western Posted April 4, 2022 Share Posted April 4, 2022 Try giving them a good spray with a lubricant, or replace the brass ball & pins, you can get these as repair kits on ebay defender rear door hinge pins I have replaced mine twice in 28 years. Quote Link to comment Share on other sites More sharing options...
Hawklord Posted April 5, 2022 Author Share Posted April 5, 2022 Thanks for your replies and I have bought the repair kit to try first and it if turns out to be worn hinges I have only lost £4.50. Quote Link to comment Share on other sites More sharing options...
western Posted April 5, 2022 Share Posted April 5, 2022 The latest hinges are not repairable so be careful which ones you buy. Quote Link to comment Share on other sites More sharing options...
