Arjan Posted April 7, 2022 Share Posted April 7, 2022 Goedemiddag, For a project I was asked if a differential was a "short nose" or a "long nose" ? Not heard diffs described that way before. - what are they ? - what is the difference ? - how to tell them apart ? Thank you. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 7, 2022 Share Posted April 7, 2022 Short nose are the rear diffs fitted in the later type 110/130 rear axles as well as the P38 (not sure about a P38 front?) Long nose is your normal D1/D2/RRC/90/110 Front diff. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 7, 2022 Share Posted April 7, 2022 As for differences... they have a different bolt pattern where they bolt up to the axle case. Not sure of the actual length difference, but side by side they're obviously different. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted April 7, 2022 Share Posted April 7, 2022 2 minutes ago, landroversforever said: Short nose are the rear diffs fitted in the later type 110/130 rear axles as well as the P38 (not sure about a P38 front?) Long nose is your normal D1/D2/RRC/90/110 Front diff. Short nose mog diffs are a pain in the A....... Regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
Arjan Posted April 7, 2022 Author Share Posted April 7, 2022 Thank You all for the quick reply. So, rear D1 axle should be a long nose ? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 7, 2022 Share Posted April 7, 2022 Just now, Arjan said: Thank You all for the quick reply. So, rear D1 axle should be a long nose ? It will be, yes Quote Link to comment Share on other sites More sharing options...
Arjan Posted April 7, 2022 Author Share Posted April 7, 2022 Thanks.. Now it is time to find out what other parts are needed to dress this axle casing up into a functioning rear axle. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted April 8, 2022 Share Posted April 8, 2022 This might help Nige Quote Link to comment Share on other sites More sharing options...
