inchman Posted January 22, 2007 Share Posted January 22, 2007 Hello, I fancy making a set of rock sliders for my 90 and hava a few questions. what is the most common size used 80X40 box or what ? and what is the most common way of securing the pipe that slides in to the tube on the chassis. does the tube on the rock slider go over the chassis tube or through it? thanks in advance Gary Quote Link to comment Share on other sites More sharing options...
Les Henson Posted January 22, 2007 Share Posted January 22, 2007 I used 100mm x 50mm H/D box section. Rear fitment is usually inside the tube and the front is by using the bulkhead outrigger bolt. Les. Quote Link to comment Share on other sites More sharing options...
s2hotdog Posted January 23, 2007 Share Posted January 23, 2007 I used 60 x 60 box the same way as the man les says Steve Quote Link to comment Share on other sites More sharing options...
landy_andy Posted January 23, 2007 Share Posted January 23, 2007 I used 60 x 60 box the same way as the man les says Steve This might help..... Cheers, Andy Quote Link to comment Share on other sites More sharing options...
Les Henson Posted January 24, 2007 Share Posted January 24, 2007 My efforts for a series vehicle (catflap) Rear brackets align with bolt holes in the fuel tank outriggers. The bulkhead bolt passes through these tabs, which are 5mm thick. (i had to buy a longer bolt to do this) Cost of materials to make the sliders was £30. Les. Quote Link to comment Share on other sites More sharing options...
inchman Posted January 24, 2007 Author Share Posted January 24, 2007 Thanks very much for all the info.. the drawing will make life so handy.. cheers Gary Quote Link to comment Share on other sites More sharing options...
inchman Posted February 7, 2007 Author Share Posted February 7, 2007 Thanks for all the help here is the finished product.. cheers gary Quote Link to comment Share on other sites More sharing options...
