Paul McCleary Posted January 23, 2007 Share Posted January 23, 2007 I've got my hands on what I think in a Stage 1 V8 Double Cardon Prop. I'd like to fit it to the front of Dodgy Bob, but the output flange from the transfer box is too small. I know the gearbox in an LT77 but I am unsure what transfer box is fitted. I suspect it is from a Defender, but I stand to be corrected. It would be nice to know as I need to order a couple of oil seals. (pictures below) My question is, can I change the output flange from the transfer box to one that would suit the DC Prop and if so, has anyone got a part number or know what model it came from that might fit? I need to change the front prop on the Bob asap as the previous owner has had the grinder and hot spanner out. I'll let the pictures tell the story. Thanks in advance. Paul. Quote Link to comment Share on other sites More sharing options...
white90 Posted January 23, 2007 Share Posted January 23, 2007 the D2 transfer box flange part number:STC4379 I think will be the correct size and this will fit the transfer box you have ok your transfer box is an LT230 Quote Link to comment Share on other sites More sharing options...
nige90 Posted January 23, 2007 Share Posted January 23, 2007 Hells Teeth, that prop is frightening Quote Link to comment Share on other sites More sharing options...
pugwash Posted January 23, 2007 Share Posted January 23, 2007 i've got a few of these props sitting in the garage- i seem to be collecting them! i "think" the output flange from a LT95 can be unbolted and re-bolted onto a LT230, or as Tony says the D2 flanges should do the trick nicely Quote Link to comment Share on other sites More sharing options...
Paul McCleary Posted January 25, 2007 Author Share Posted January 25, 2007 Thanks for the replies. I'll get one of those on order ASAP. Ref the original prop. I'm stunned it has lasted as long as it has. Apparently it was modded by the original builder of the Bob a few years ago and has claimed the lives of 2 front diffs in the hands of the previous bodge merchant, and still refused to fail. It won't be claiming any more victims, as it's now thrown in the scrap skip where it belongs. Paul. Quote Link to comment Share on other sites More sharing options...
