Sharp Posted April 25, 2022 Share Posted April 25, 2022 I'm assuming fuel draining back into the tank somehow. If it's sat for a while (few hours or so) and I turn the key it fires up then immediately dies as if it's burned whatever was left and then run out, after about 10 seconds of cranking it starts up and will start up again straight after. Not experienced any loss of power while driving. Could a faulty lift pump cause this? I had the tank out and fitted a new fuel filter a few months ago but has been running ok since then. The other day I took the key out of it quite quickly and it kept running for a few seconds but hasn't done that since. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted April 25, 2022 Share Posted April 25, 2022 Loose joint in the fuel system somewhere. The leak off lines on the injectors are a classic for this. Quote Link to comment Share on other sites More sharing options...
Snagger Posted April 25, 2022 Share Posted April 25, 2022 Start by replacing the braided leak off pipes between the injectors - they perish and leak air in, allowing fuel to drain back to the tank when sat. That makes starting far more difficult. LR only sell a complete harness with the hoses, all unions and the plastic pipe to the injection pump, and that cost £85 over a decade ago. Halfords and other motor factors sell 1m rolls of the hose (3.5mm, IIRC) for a few pounds… Quote Link to comment Share on other sites More sharing options...
Sharp Posted April 25, 2022 Author Share Posted April 25, 2022 Thanks both. Upon closer inspection there looks to be diesel around the injectors so it looks like you're correct with your diagnosis. I've ordered some pipe up 1 Quote Link to comment Share on other sites More sharing options...
cackshifter Posted April 26, 2022 Share Posted April 26, 2022 I put heat shrink sleeve over the ends to stop the braid from fraying, I think 7mm from memory, as long as it's a reasonably tight fit the heat of the engine does the final shrinking. 2 Quote Link to comment Share on other sites More sharing options...
Peaklander Posted April 27, 2022 Share Posted April 27, 2022 One of mine frayed and the end split two days ago. It’s at #1 where it goes back to the pump. We were doing a few miles and started to smell diesel. By the time I looked there was a nice coating of the smelly stuff and it was dripping off the steering arms. For the time being I trimmed the end and it’s ok. The heat shrink is a good tip 👍🏻 Quote Link to comment Share on other sites More sharing options...
Sharp Posted May 4, 2022 Author Share Posted May 4, 2022 Just to follow up: I ordered some 3.2mm hose and that fixed the proplem. Thanks for the help. 1 1 Quote Link to comment Share on other sites More sharing options...
