300Tdi Discovery 1 - Water Pump Issue
Jim Mason
Help...
Nearly blown engine again - short drive to check steering issue - Landy increased in temp rapidly.
Got home expansion tank cold, heater in landy cold.
Removed pipes all dry no fluid - just steam.
Took top hose off water pump started engine - no fluid being pumped
Stripped pump - still attached nothing loose
What could be going wrong - is she sucking in air or air locked?
Both plugs out
Fill the header tank to the seam , fit cap tight
fill rad through plug hole until full , it takes a little while to fully settle full . Fit plug tight.
fill thermostat housing through the plug hole . Fit plug tight.
That should do it .
Check those bleed off pipes too .
Putting an impellor pump at the top of the system full level is utterly beyond me .
But as we are all too aware JLR made lots of questionable engineering choices....:)
Steve
  • Thanks 1
On 5/2/2022 at 10:14 PM, Anderzander said:
Has it been leaking out the tell tale hole ?  If the seals in the water pump go they can lose a lot of water out of there ..
Not noticed - only drove her 1 mile - trying to sort steering issue.
Its not entirly clear picture, but the pump vains - looks different to any type I've seen before, I'm more familier with the stamped steel type - if you google you can see many like it, the pump vains look a good bit longer - but I guess pumping is kind irrelevant if ther's no water in the pump to start off with?
