Discovery (1996) rear diff pinion seal
I am having difficulty identifying the correct pinion seal for my rear diff. Axle is off a P reg Disco V8, had a 3-bolt rear flange with the donut on. I've swapped for a 4-bolt flange (STC4858) so bear that in mind...
I had mudshield LR017552 already, which should fit seal FTC5258.
  Having ordered that seal, it was far too small so I'm a bit confused as it's matched to that mudshield.
Should a 1996 Disco have a different seal/mudshield to the above?
1 hour ago, ThreePointFive said:
Thanks Ralph but therein lies the problem; I can buy it as a kit but I can't find the correct part numbers for just the seal and mudshield.
I don't want to buy another flange!
If you click on the other item numbers it will show the part numbers as well,
  • 2 weeks later...
Both, mostly diameter though. In the end I ordered FRC8220 which was very different from the original and much thicker, but the casing is cut deep enough to accept it. It's not "right" because the mudshield FRC8154 is a completely different design and I don't think will do much of a job, but I am content to run it as-is for now unless there is an obvious bad reason for fitting a thicker seal.
  • Like 1
