Defender 90 4" lift problems
Hi everyone,
I'm new to the forum so apologise for being a noobie
I have bought a 1992 defender 90 200tdi with, I suspect a 4" lift front and back, without castor correction and using polybushes and spacers.
What are the problems with this set up in relation to the driveline? i've just had a reconditioned LT77 fitted and worried the lift somehow stresses the gearbox or diff?
Thanks for advice
Oli
No i don't see much advantage to the lift but it's how i've bought it, i will be removing the lift when i have the available funds - going back to something more original as i mainly want to use it on the road, green lanes and light off roading. I was wondering what i need to look out for in the meantime? thanks
If you can yank the spring spacers out, very likely you will be able to lower it for £0.....
Without pics, hard to be sure, but could be a really cheap way through.
Stress with that kind of lift is normally propshafts due to the running angle, nothing really else in the driveline.
  • Like 4
