Redfern92 Posted June 21, 2022 Share Posted June 21, 2022 (edited) Hi guys hope somebody could shed some light on this. I washed the landrover Sunday night and noticed water running down the inside of the windscreen. Later that night the alarm started going off I went and turned it off and when I tried to lock it it wouldn’t lock just a sound of the horn so I opened and closed all doors boot and bonnet and still the same, I’ve tried the bonnet plug and that’s fine, now I’ve noticed the stereo stays on and doesn’t turn off when the ignition goes off. Anyone had the same problem? Edited June 24, 2022 by western Title changed to be more relevant to subject Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted June 21, 2022 Share Posted June 21, 2022 What model of Discovery is this? Regards. Quote Link to comment Share on other sites More sharing options...
Redfern92 Posted June 21, 2022 Author Share Posted June 21, 2022 22 minutes ago, David Sparkes said: What model of Discovery is this? Regards. Sorry. It’s a discovery 2 2003 Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted June 21, 2022 Share Posted June 21, 2022 I would start with water ingress. Probably somewhere close to the control modul for eeverything that's gone wrong. Quote Link to comment Share on other sites More sharing options...
bear Posted June 24, 2022 Share Posted June 24, 2022 Check the interior fuse box on the drivers side. Griff 1 Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 26, 2022 Share Posted June 26, 2022 Water in the fuse box on the driver's side causes all sorts of electrical weirdness. As to the leak - sunroofs or roof rails if fitted, windscreen sealant if not. 1 Quote Link to comment Share on other sites More sharing options...
