chrispy Posted January 24, 2007 Share Posted January 24, 2007 Morning all, the front windscreen washer pump in my 92 Vogue SE has given up the ghost. I got a replacement, but I'm not sure how to go about fitting it. Am I correct in assuming it just pushes into place in the reservoir (and therefore removing the broken one just means pulling it out, after removing cables and tubes, of course)? Also, any ideas on how to drain the reservoir before doing this would be most appreciated... Thanks, Chris Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 24, 2007 Share Posted January 24, 2007 I think they do push-in yes. As for draining it - you could siphon it out, but I reckon if you're quick you will be able to get the old one out and the new one in without losing too much water. Quote Link to comment Share on other sites More sharing options...
