MECCANO Posted January 24, 2007 Share Posted January 24, 2007 well i would very much like to bolt these to items together. The problem i have, is the type of starter motor on the series engine sticks out into the bell housing on the series gearbox. the lt77 from a 90 dosent allow this to happen. Does such a bell housing exist? or am i going to have to fit a 90 2.5 pet starter, flywheel etc? chars muchly Quote Link to comment Share on other sites More sharing options...
Jon White Posted January 24, 2007 Share Posted January 24, 2007 Fit 2.5 flywheel and starter motor mate. There is only one bellhousing available. Dont forget you'll also need a defender clutch plate. Cheers Jon Quote Link to comment Share on other sites More sharing options...
MECCANO Posted January 24, 2007 Author Share Posted January 24, 2007 Fit 2.5 flywheel and starter motor mate. There is only one bellhousing available.Dont forget you'll also need a defender clutch plate. Cheers Jon So it might just be easier to bolt the tdi in at the same time, instead of faffing around checking the box works fine on the 2.25 first Quote Link to comment Share on other sites More sharing options...
Gremlin Posted January 24, 2007 Share Posted January 24, 2007 Yes Grem Quote Link to comment Share on other sites More sharing options...
