Dan_90 Posted July 6, 2022 Share Posted July 6, 2022 i have a 15p 2003 (165,000miles)td5 discovery that has never rev'd up all the way it would act as if there was a limiter at 4000-4250 when standing still and then 3250 sometimes when moving as if its struggling it would jump kinda i have rebuilt the pressure reg with a bosch kit to try solve it also tryed a genuine pump and done injector seals (not sure if it has anything to do with it but did the seals about a month ago and already seem to if failed 3rd time i have done them (all were allmakes4x4) ) the head dosent look cracked and no diesel in the oil not sure what to do next to try cure the problems Quote Link to comment Share on other sites More sharing options...
bear Posted July 7, 2022 Share Posted July 7, 2022 Hi, I'm no expert but I think reving it that high does seem a bit excesive. I don't feel the need to go above 3000 rpm. Griff Quote Link to comment Share on other sites More sharing options...
Dan_90 Posted July 7, 2022 Author Share Posted July 7, 2022 7 hours ago, bear said: Hi, I'm no expert but I think reving it that high does seem a bit excesive. I don't feel the need to go above 3000 rpm. Griff not at all the limiter is at 5000 , i feel the need for power and sound Quote Link to comment Share on other sites More sharing options...
Mesigan Posted August 21, 2022 Share Posted August 21, 2022 Hi Apologies to resurrect this thread but when last was the injector harness changed. I had the same effect. In SA some refer to if as the kangaroo jump😀 I had the injector harnesses changed and it stopped this kangaroo effect. Regards Mesigan Quote Link to comment Share on other sites More sharing options...
Dan_90 Posted September 10, 2022 Author Share Posted September 10, 2022 On 8/21/2022 at 8:56 AM, Mesigan said: Hi Apologies to resurrect this thread but when last was the injector harness changed. I had the same effect. In SA some refer to if as the kangaroo jump😀 I had the injector harnesses changed and it stopped this kangaroo effect. Regards Mesigan not a problem , changed the harness with seals Quote Link to comment Share on other sites More sharing options...
