Honi987 Posted July 27, 2022 Share Posted July 27, 2022 Pls help I'm building a td5 110 csw. I am using a td5 disco donor engine and have the disco engine and bulkhead loom. Can anyone help me with the pin diagrams for the speedo plugs from the disco speedo connectors & also diagrams for the defender loom speedo connectors so that I can modify this disco loom to plug into my defender td5 Speedo. I just cannot afford the stupid prices folk are asking for used defender td5 bulkhead looms online. Quote Link to comment Share on other sites More sharing options...
western Posted July 29, 2022 Share Posted July 29, 2022 1. Is this a rebuild of an existing Td5 Defender or a ground up build on a new galv chassis, 2. What's wrong with the Defender Td5 looms ? Quote Link to comment Share on other sites More sharing options...
Honi987 Posted July 30, 2022 Author Share Posted July 30, 2022 15 hours ago, western said: 1. Is this a rebuild of an existing Td5 Defender or a ground up build on a new galv chassis, 2. What's wrong with the Defender Td5 looms ? It's a ground up build. Was a 2.5t rd pre tdi. I bought disco td5 donor. this has been huge and expensive mistake. I may as well have started with 3mm sheet steel and a welder. I've had to change soooooo much. but anyway. I got mostly everything, just on with wiring. I have a Dixon's Fabrication box and programme d ecu, running off Bosch 044 pump. I just need to sort bulkhead loom for speedo. But cannot find disco td5 bulkhead loom speedo connector pin diagram. So I could compete with defender and see if I can modify the dis o td5 loom and add defender td5 Speedo plugs Quote Link to comment Share on other sites More sharing options...
Honi987 Posted July 30, 2022 Author Share Posted July 30, 2022 16 hours ago, western said: 1. Is this a rebuild of an existing Td5 Defender or a ground up build on a new galv chassis, 2. What's wrong with the Defender Td5 looms ? I haven't a defender td5 bulkhead loom, just a discovery one. Defender td5 bulkhead looms are stupid expensive Quote Link to comment Share on other sites More sharing options...
