blz6662 Posted August 19, 2022 Share Posted August 19, 2022 Hi Guys, Can the upper tank strap be replaced without removing the petrol tank? I discovered the lug attachment that is welded to the chassis on the drivers side is no longer welded to the chassis. Therefore I've cut out all the rot out of the chassis and made up at repair plate with a new mounting plate on ready to accept a new lower slotted bracket for the strap. On inspection and bending the strap out of the way it may last another year or so but wondered if it was possible to undo the strap from the near side and pull it through so I can replace it now while I'm in there - as they say, who ever they are! Thanks in advance blz6662 Quote Link to comment Share on other sites More sharing options...
