FridgeFreezer Posted September 4, 2022 Share Posted September 4, 2022 Per the title really - the 127 has a Gemmer 6-bolt "heavy duty" box and I'd like to source a spare arm for it to rebuild the ball joint, but it's not entirely clear if they share arms with the more common 4-bolt boxes? RTC6398/RTC6399 is the part according to LRWorkshop (not sure what the difference is?) where the 4-bolt flavour has a different part# so there's clearly something going on. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted September 5, 2022 Share Posted September 5, 2022 My understanding is that the Gemmer and Adwest boxes have a different taper/spline for the drop arm, and so are not compatible. A 4-bolt Adwest will take the same arm as a 3-bolt Adwest. But a 6-bolt Gemmer is different. However the 4-bolt Adwest and 6-bolt Gemmer both take the same (metric) pipe fittings, whereas the 3-bolt Adwest takes different (imperial) fittings. 2 Quote Link to comment Share on other sites More sharing options...
