Anderzander Posted September 6, 2022 Share Posted September 6, 2022 Couple of questions: Would you use 609 for a bearing race that is a little loose? Also - I don’t seem to have much luck with the ones where you pull up to open, they seem to keep drying in the tube even with using the top. So I guess Im asking what the best type of bottle is? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 6, 2022 Share Posted September 6, 2022 Loctite's technical helpline are usually pretty good for questions, including where to buy it for a reasonable price etc. Although last time the loctite rep visited me had had a bad batch that made a horrific sticky mess everywhere, felt quite bad for him! 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted September 12, 2022 Share Posted September 12, 2022 I've used it on stuff like that in the past at work. It's what we used for a number of assemblies with bearings that needed to be fitted somewhere we didn't have a press or a way of drawing them in. As long as it's not so loose it can move around as it needs no air present to cure if I remember correctly. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted September 12, 2022 Share Posted September 12, 2022 And for the bottle type.... I've not had any real issues with the big bottles with the lift up section, occasionally end up with a little solidified plug to remove, but it's always come out with squeeze. If you don't need much, might be best getting one of the little bottles. Quote Link to comment Share on other sites More sharing options...
