Cornish Rattler Posted September 17, 2022 Share Posted September 17, 2022 Hi guys Does anyone know if a NATO hitch bolts straight onto a CIVVY 88" rear X member please. Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted September 17, 2022 Share Posted September 17, 2022 Yes I do, and NO it doesn't. You need an external adaptor plate which comes with stand-off legs (tubes) so the nuts for the NATO hitch can be accessed. Try 245599. Nowadays, preferred use includes a securing point, or points, for safety chains. Regards. Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted September 17, 2022 Author Share Posted September 17, 2022 53 minutes ago, David Sparkes said: Yes I do, and NO it doesn't. You need an external adaptor plate which comes with stand-off legs (tubes) so the nuts for the NATO hitch can be accessed. Try 245599. Nowadays, preferred use includes a securing point, or points, for safety chains. Regards. Ok cheer's i will look into that 👍 Quote Link to comment Share on other sites More sharing options...
pete3000 Posted September 17, 2022 Share Posted September 17, 2022 You can pick up the wolf plates for the safety chains for cheap on the bay, https://www.ebay.co.uk/itm/303328882760 These make good spreader plates with some suitably rated bolts and double half nuts (for locking up) Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted September 17, 2022 Author Share Posted September 17, 2022 3 hours ago, pete3000 said: You can pick up the wolf plates for the safety chains for cheap on the bay, https://www.ebay.co.uk/itm/303328882760 These make good spreader plates with some suitably rated bolts and double half nuts (for locking up) Is that plate not just for a defender though as the series ones have 8 holes 🙂 Quote Link to comment Share on other sites More sharing options...
Chicken Drumstick Posted September 17, 2022 Share Posted September 17, 2022 6 hours ago, Cornish Rattler said: Hi guys Does anyone know if a NATO hitch bolts straight onto a CIVVY 88" rear X member please. You’d need to drill 2 holes for the nato hook. As the crossmember won’t have them. It will then fit. But you’ll need a spreader plate at the back. And really one on the front, as the crossmember can easily be deformed. Lots of different ways of achieving this. Will you be towing? On my 88 I fitted a drop plate and then have a nato on one slider and a regular hitch on another. Also allows you to adjust the height. Quote Link to comment Share on other sites More sharing options...
Chicken Drumstick Posted September 17, 2022 Share Posted September 17, 2022 Here is how I first had it with the mil style spreader plate. Then how I fitted it with a slider afterwards. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 17, 2022 Share Posted September 17, 2022 Honestly I'd put it on a slider, then it fits, and you can swap on a normal tow ball by changing out the slider part. 1 Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted September 17, 2022 Author Share Posted September 17, 2022 2 hours ago, Chicken Drumstick said: You’d need to drill 2 holes for the nato hook. As the crossmember won’t have them. It will then fit. But you’ll need a spreader plate at the back. And really one on the front, as the crossmember can easily be deformed. Lots of different ways of achieving this. Will you be towing? On my 88 I fitted a drop plate and then have a nato on one slider and a regular hitch on another. Also allows you to adjust the height. Yes i have a 109 drop plate but i had forgoten about the drop plate being on so yeah that would work 👍 Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted September 17, 2022 Author Share Posted September 17, 2022 2 hours ago, Chicken Drumstick said: Here is how I first had it with the mil style spreader plate. Then how I fitted it with a slider afterwards. Can you still get series sliders as the bolt hole patern is slightly different to a series or can i mod it to suit Quote Link to comment Share on other sites More sharing options...
