Exmoor Beast Posted September 20, 2022 Share Posted September 20, 2022 I had an 'auto handbrake release failure' error come up recently. I eventually found a fix for this online so just recalling it here so it may help someone else. It appears its an XYZ sensor problem that can be reset by finding a long straight road, you need to reverse until R registers on the dash indicator thenย engage first gear and drive up through the gears to sixth waiting for the dash indicator to register the gear each time. then stop and turn off, remove the key lock and unlock the doors. Key back in and turn on the ignition, problem solved! Woohoo, a free fix! ๐ you owe me a pint if this helps. Will ๐ 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 20, 2022 Share Posted September 20, 2022 The joy of modern stuff!ย ย 1 Quote Link to comment Share on other sites More sharing options...
Exmoor Beast Posted September 20, 2022 Author Share Posted September 20, 2022 5 hours ago, Bowie69 said: The joy of modern stuff!ย ย Indeed, still nothing has stopped it running yet, its only a matter of time I know. Only other fault to date has been a leaking fuel filter, stupid bayonet fitting shook itself loose. Easy fix if a little messy. Will ๐ 1 Quote Link to comment Share on other sites More sharing options...
