Arjan Posted September 25, 2022 Share Posted September 25, 2022 Rear Diff gave up so I need to replace it. Found a front axle - nothing is known about it. This is the diff :Looks in good usuable condition ? Do these numbers tell us anything ? Thank you. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted September 25, 2022 Share Posted September 25, 2022 The numbers are just casing numbers no exact reference or meaming a series diff is 4.7:1 ratio a number of different casing but basically either a one piece casing or a 2 piece with an anuminium front bolt on nose piece Quote Link to comment Share on other sites More sharing options...
Arjan Posted September 26, 2022 Author Share Posted September 26, 2022 Thank You. So there is no way to "date" either the differential or the diff itself... Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted September 26, 2022 Share Posted September 26, 2022 No, I can get close from pictures with a date range - that's providing its the right diff in there !! Or Tell you / pics of what it should be in there ! Nige Quote Link to comment Share on other sites More sharing options...
Arjan Posted September 27, 2022 Author Share Posted September 27, 2022 This is just for entertainment purposes (.....) I removed the rear diff of the Hybrid last night as it stopped working in a rather spectacular way while towing a trailer... It seems some bolts worked loose... Hope to replace the diff tonight for another one..... 1 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted September 28, 2022 Share Posted September 28, 2022 Oh dear. Was it exciting when it went through a rapid unscheduled disassembly? Quote Link to comment Share on other sites More sharing options...
mickeyw Posted September 28, 2022 Share Posted September 28, 2022 The only diff failures I've ever had were also caused by the crownwheel bolts coming loose and shearing. Your diff looks like it's been using too much of that special dry lube 😲 Quote Link to comment Share on other sites More sharing options...
Arjan Posted September 30, 2022 Author Share Posted September 30, 2022 It came apart in a rather noisy and vibrating way and I must say it made for an interesting evening.. Quite a bit of oil came out, with quite a bit of debris, when drained to remove the diff. However, I'm not sure about the axle breathers doing what they should do over the decades so i'll take this moment to fit these : On the OneTen they work fine... Quote Link to comment Share on other sites More sharing options...
