Stambecco Posted January 13 Share Posted January 13 Is anyone able to provide the part number for the above? Vehicle, Defender 200Tdi 1990 (H). (RHD) It looks like it's QRF100880. It has had multiple part numbers which have been superseded. It could also be LR077439. Paddock says defender 200tdi but others say from 1991, others say something different again. Thanks very much. Quote Link to comment Share on other sites More sharing options...
western Posted January 13 Share Posted January 13 110 parts book shows PRC8230 for both 200tdi & 300tdi Vehicles Comes up on Brit-car website as LRO35359 Now LRO39638 Lucas part nber SQB136 Quote Link to comment Share on other sites More sharing options...
Stambecco Posted January 13 Author Share Posted January 13 Thank you. The PRC8230 is only the round connector block on the end. I need the whole unit, including barrel. There doesn't seem to be any consistency between suppliers. Quote Link to comment Share on other sites More sharing options...
western Posted January 13 Share Posted January 13 you need the steering lock assembly then, that's NTC7855 up to VIN LA932973, ClamP NRC7422, 2 x SHEAR BOLTS 51K4001L, Washer x 2 WB108051L,Key blank AAU8276, all on page 711 of 110 parts book 1987 onwards, there is a copy on Retroanaconda's website. you can just replace the electrical switch part, without removing the steering lock, there is a small screw that keeps the switch in place, its a fiddly job but can be done. Quote Link to comment Share on other sites More sharing options...
Stambecco Posted January 13 Author Share Posted January 13 Thank you very much. The ignition key doesn't stay in position, sometimes but not always, so I think I need the lot. So QRF100880 which is listed for 200Tdi, is wrong? It looks the same. Quote Link to comment Share on other sites More sharing options...
western Posted January 13 Share Posted January 13 That QRF number is good see Supersession note on here https://parts.jaguarlandroverclassic.com/qrf100880-lock-assembly-steering-column.html LR tend to update part numbers, from 7 digit to 9 digit so thats the latest updated number Quote Link to comment Share on other sites More sharing options...
Peaklander Posted January 13 Share Posted January 13 I have just removed one from my 300TDi as I have moved to later size keys. I have the whole steering lock with ignition switch, (no clamp), two keys and three barrels (all working). I still have to remove two of the barrels from the doors. Quote Link to comment Share on other sites More sharing options...
Stambecco Posted January 13 Author Share Posted January 13 Thanks but I'm away from the the UK at the moment.👍 Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted January 14 Share Posted January 14 If you fit the later type you get the much nicer keys, and can have them match the door locks too. 1 Quote Link to comment Share on other sites More sharing options...
