Defender 300 Tdi 10as main components
Hi,
I've got a Defender in at the moment with a mostly removed faulty 10as.
The siren, seatbox ECU and associated wiring has been removed and some additional wiring added by a previous person for the start and FIP solenoid.
When the battery is low all the indicators flash occasionally 2 or 3 times with ignition off as they would off the key fob alarm set/off buttons. When voltage is normal this does not happen.
Any pointers as to the root of this issue?
All systems work correctly apart from this rather odd fault.
Thanks
Steve
